My new toys
My new toys
Pages (177): Previous 199 100 101 102 103177 Next
18-05-2018, 05:50 PM
Gord Nice one mate, its going to be one nice is200 when all finished off mate Big Grin
Hopefully yes mate!
18-05-2018, 05:50 PM #1,001
Hopefully yes mate!
19-05-2018, 12:35 AM
Still coming on very well mate :thumbup1: did you ever sort anything out about the supercharger heat now your running at higher boost? or has it not really made much difference to it? looking very good mate :thumbup1:
19-05-2018, 12:35 AM #1,002
19-05-2018, 06:35 AM
Bandit Still coming on very well mate :thumbup1: did you ever sort anything out about the supercharger heat now your running at higher boost? or has it not really made much difference to it? looking very good mate :thumbup1:
Hi mate, the supercharger runs ok, no problems with heat at higher boost.
19-05-2018, 06:35 AM #1,003
19-05-2018, 11:58 PM
dimis Hi mate, the supercharger runs ok, no problems with heat at higher boost.
That's cool then mate, :thumbup1:
Need to get my rear in gear and sort mine out with the bigger pulley and other parts, its not running too bad at the moment and seems to be pushing 0.4bar most of the time? but still think its not getting enough fuel? Blush
19-05-2018, 11:58 PM #1,004
22-05-2018, 11:20 PM
Bandit That's cool then mate, :thumbup1:
If you are using and HKS FCD then your definetely need a better ECU. Make sure that you fit piggy before you fit your bigger pulley otherwise you will not have any improvements and might break your engine. With the 160mm pulley the boost will be around 0.6 to 0.65bar mate, too much for the FCD to handle. Make sure you that you also install a bigger FMIC, injectors and a map sensor.
22-05-2018, 11:20 PM #1,005
22-05-2018, 11:29 PM
Did you notice a big difference with just the 150mm pulley compared to the standard one ?
Its just because we all need a bit more power Big GriniscoStu:
22-05-2018, 11:29 PM #1,006
23-05-2018, 05:05 AM
Moley is 255hp at the flywheel ok for you mate? This is my power output.
23-05-2018, 05:05 AM #1,007
23-05-2018, 05:06 AM
Moley Did you notice a big difference with just the 150mm pulley compared to the standard one ?
23-05-2018, 05:06 AM #1,008
23-05-2018, 05:12 AM
That sound just about right :thumbup1:
So when is the pulley up for sale then ??
23-05-2018, 05:12 AM #1,009
23-05-2018, 09:42 PM
Moley That sound just about right :thumbup1:
Soon mate, soon. Once I have gathered all the necessary parts for the stage 2 upgrade and fitted all the parts i have collected the last few months, you can have the pulley. I will let you know.
23-05-2018, 09:42 PM #1,010
 5 Guest(s)
 5 Guest(s)
