My new toys
My new toys
Pages (177): Previous 1105 106 107 108 109177 Next
21-08-2018, 07:01 AM
well you needed an excuse to do it anyway mate, just a shame you've damaged it to force the swap quicker, but it will look good when its redone so there is a positive to it
21-08-2018, 07:01 AM #1,061
21-08-2018, 07:48 AM
is300_dino well you needed an excuse to do it anyway mate, just a shame you've damaged it to force the swap quicker, but it will look good when its redone so there is a positive to it
Yes mate, you are correct. This is a good excuse I believe to fit the lip and sport grill
21-08-2018, 07:48 AM #1,062
29-08-2018, 11:25 PM
I just purchased a set of Megan Racing Traction Rods from USA. I just have to find know a good set of uprated bushes for my front suspension system and then off to the WIM.
29-08-2018, 11:25 PM #1,063
31-08-2018, 12:17 PM
Just being back from the garage. I changed the differential mounts, which appeared to be nakared, and the clutch line with the APP high pressure line. The new differential mounts made a big difference. The car does not kick so much when pushing or leaving the gas pedal. Now regarding the high pressure clutch line i have not seen any differences yet...
[Image: ndlt9x.jpg]
31-08-2018, 12:17 PM #1,064
[Image: ndlt9x.jpg]
31-08-2018, 12:20 PM
did you fit standard mounts or solid ones?
31-08-2018, 12:20 PM #1,065
31-08-2018, 12:24 PM
Sparkystav did you fit standard mounts or solid ones?
No mate, OEMs. I was thinking of fitting solid ones, but I read it stiffness the diff and my car is already too stiff.
31-08-2018, 12:24 PM #1,066
31-08-2018, 12:26 PM
fair enough, what was the cost of them?
31-08-2018, 12:26 PM #1,067
31-08-2018, 12:42 PM
Sparkystav fair enough, what was the cost of them?
79pounds from Lexus garage mate.
31-08-2018, 12:42 PM #1,068
31-08-2018, 12:44 PM
not too bad at all!
31-08-2018, 12:44 PM #1,069
not too bad at all!
01-09-2018, 12:32 AM
I might need to change the gearbox mounts also. I have never changed them and if I judge from the conditions of the diff mounts I think it is a must especially now with has more power than in OEM setup and with 120,000km on the clock.
01-09-2018, 12:32 AM #1,070
