JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza heater led swap
heater led swap
heater led swap
Pages (16): Previous 110 11 12 13 1416 Next
23-05-2018, 03:09 AM
jay_russell ok mate. good news, you might have to swap them around if they dont work Smile leds run only one way. simple to do. remove the 4 screws on the back of the unit and there you will see a blub holder with a black and red wire comming out of them just do a 180 on it so it sits the other way, same with the clock. i cant test it on mine as it's different fittings Smile and yes :ttiuwp: and i cant wait to see the pics of it fitted and looking good
Ok so the clock works and so dose the heated window switch and the air con and the one for air coming from outside car. The one for recycling the air in the car dose not work neither do the lights for the temperature , the fan settings or the direction for the air flow . Do I need to take out the control panel and do something in there ???
23-05-2018, 03:09 AM #111
23-05-2018, 03:28 AM
Moley, take the unit out of the car (make a note of the ones that are not working first), turn the unit around and remove the 4 screws holding the unit face on. For each bulb that's not working, pop it out and put it back in turned 180 degrees. Then they should all work Smile
:biggrin: that's my understanding of Jay's post on what could possibly go wrong, anyway...
23-05-2018, 03:28 AM #112
23-05-2018, 03:32 AM
DaveEdin Moley, take the unit out of the car (make a note of the ones that are not working first), turn the unit around and remove the 4 screws holding the unit face on. For each bulb that's not working, pop it out and put it back in turned 180 degrees. Then they should all work Smile
Beat me to it Dave! That sounds about right. LED bulbs will only work one way, though can easily be fitted either way. I believe Jay has essentially just guessed! As he was not able to test his end. A quick 180 should see those ones lit also.
23-05-2018, 03:32 AM #113
23-05-2018, 03:36 AM
Happened to me when I did my dash lights Stoney...
23-05-2018, 03:36 AM #114
23-05-2018, 03:41 AM
When you take the back off , which I have done all you get is a circuit board and you cant see the bulbs. but there is a black and red cables that have a bit of silicone on them so you cant do anything to them.
Not sure if I should remove the circuit board and start messing about inside or not !!
23-05-2018, 03:41 AM #115
23-05-2018, 05:10 AM
DaveEdin Happened to me when I did my dash lights Stoney...
Me too! Years ago.
Moley When you take the back off , which I have done all you get is a circuit board and you cant see the bulbs. but there is a black and red cables that have a bit of silicone on them so you cant do anything to them.
Never opened this particular unit, I'm speaking generically about LEDs, so can't help here, sorry. Jay'll be along soon, I'm sure.
23-05-2018, 05:10 AM #116
Me too! Years ago.
23-05-2018, 05:58 AM
Jay said the black and red cables led to the bulb holders, shouldn't they just twist out in order to access the bulbs?
23-05-2018, 05:58 AM #117
23-05-2018, 06:31 AM
Yes, I imagine they are twist and pull to remove, a bit like a bayonet light bulb in your house! Then the LEDs pull just out the holder, reverse them and fit them back in. (Guessing here, but expect I am right.)
23-05-2018, 06:31 AM #118
23-05-2018, 07:12 AM
yer mate, just turn around the bulb holder with the red / black wires in it and the fit it again, it's hard as they dont fit in my car so i cant test it 100%, but after i have done the last one i can send you the unit to replace the not working bulb.
23-05-2018, 07:12 AM #119
23-05-2018, 07:29 AM
Going away to try it now mate
23-05-2018, 07:29 AM #120
Views 622
19-09-2020, 10:59 AM
Views 338
02-08-2019, 08:54 AM
Last Post by Almost Finished
Views 387
24-01-2019, 12:14 PM
Last Post by Jaminglish
Views 1,175
04-11-2018, 05:02 AM
Last Post by Stoney
Replies 26
Views 1,800
01-03-2018, 08:54 PM
Last Post by James S
Views 838
03-11-2017, 10:16 PM
Views 307
13-09-2017, 09:28 AM
Last Post by lex2oos
