Lexus IS200 Fog/Brake conversion Diode Kit
Stoney Fog to Brake mod On/Fog to Brake mod Off?
as above^^^why would you want to switch it on and off ?its not illegal
^^^ I don't see the point either!
I have the fog to brake mod, but after seeing others with a quad rear light mod, I really like it. (More than a little bit 'Skyline' looking from a distance!) Been thinking of getting dual filament bulbs in the fogs and trying to figure out the wiring to make all four lights act as normal lights and brake lights.
^^^ Done it get on ebay and hunt the breakers for standard bulb holders that's what I used and now I have all 4 as normal/brake lights and the Fogs still work
the flasher unit goes inline before the bulbs their for youd have to wire the switch infront of that so you turn off the flasher unit you turn off the brake lights....
That's a lot of messing around Dean IMHO what would be the point in fitting them to then turn them off easier not to fit them and spend the money on other things
Lexuspat That's a lot of messing around Dean IMHO what would be the point in fitting them to then turn them off easier not to fit them and spend the money on other things
Lexuspat ^^^ Done it get on ebay and hunt the breakers for standard bulb holders that's what I used and now I have all 4 as normal/brake lights and the Fogs still work
Have l look for "Switchback" LED's in the size/shape you require.
