JapCarForum Cars, Cars, Cars! Project Cars My IS300 story so far....
Pages (28): Previous 112 13 14 15 1628 Next
19-05-2018, 05:07 AM
Chuck a PM @ Rabster or The_Stig, maybe it's an option that can be added easily...
We already have the share feature, which posts a thread link to facebook, so maybe it's just something needing enabled?
19-05-2018, 05:07 AM #131
19-05-2018, 05:31 AM
I had a camera mounted in the front bumper, however being exposed to the elements it soon broke.
gonna install my new one in the passenger side headlight where the full beam is, it will match my mod on the driver side with the intake
19-05-2018, 05:31 AM #132
19-05-2018, 06:39 AM
Sparkystav gonna install my new one in the passenger side headlight where the full beam is, it will match my mod on the driver side with the intake
Still waiting intently for more photos of this Stav!
19-05-2018, 06:39 AM #133
19-05-2018, 06:51 AM
Continuing last week's discussion about your rad.
I just turned out this:
[Image: 265904_10150224532226491_540486490_79009...6981_o.jpg]
[Image: 258164_10150224532106491_540486490_79009...4130_o.jpg]
Might it be of any use to you?
19-05-2018, 06:51 AM #134
19-05-2018, 11:34 AM
Stoney Continuing last week's discussion about your rad.
In a word mate.....yes!
The top tank bit looks exactly the same as my IS300 one. Doe sit look easy to remove to you?
19-05-2018, 11:34 AM #135
19-05-2018, 01:51 PM
In a word mate..... No!
Looks to be held on my about a hundred metal tabs?
Can we get info form someone who has done it?
I could send you the whole rad...... and let you figure it out!
19-05-2018, 01:51 PM #136
19-05-2018, 09:50 PM
Stoney In a word mate..... No!
Ahh that sounds like a right PITA. The only reason I thought that it might have been able to do was because you can buy just the top tank from Toyota.
However, thinking about it, that top tank bit is going to be under a schnitzel load of pressure so its probably not designed to be an easy job.
Is your rad punctured?
19-05-2018, 09:50 PM #137
19-05-2018, 09:59 PM
Jim it is not advised to open the top or bottom of the clamps on the rads.
All you will find is one rubber seal and access to the fins.
I doubt very much that your be able to re seat it back as it was.
Sorry mate no real short cuts.
Edited 01-07-2011, 07:34 AM by Lexusboy.
19-05-2018, 09:59 PM #138
19-05-2018, 10:05 PM
Lexusboy Jim it is not advised to open the top or bottom of the clamps on the rads.
Cheers for clearing that up matey. :Sulk:
Luckily though I think I've found a hose connector that I should be able to screw into the snapped off pipe. Its from a spray gun, but has a 5mm diameter threaded male connector on one end and a 1/8" female connector on the other.
With a bit of gentle drilling/tapping I think I should be able to get the 5mm end to screw into the snapped off bit, and then I've got a standard 1/8" connector to put whatever size hose barb on I want.
Then that'll see me good until my Mishimoto radiator and trans cooler arrives Wink
19-05-2018, 10:05 PM #139
20-05-2018, 12:11 AM
This may be the case.
Strange Toyota sell the tops though? I would have though any excuse to sell you a more expensive part - And that would be an acceptable excuse!
Yes Jim, the rad is leaking, but it's only quite a small hole, somewhere near the middle, you could probably liquid metal it and use the rad.
If ya fancy giving it a go, either changing tops or patching the hole, the whole rad is yours for postage cost, sub £10 I'd imagine.
20-05-2018, 12:11 AM #140
 7 Guest(s)
 7 Guest(s)
Views 1,404
12-02-2023, 05:38 AM
Replies 32
Views 2,975
12-02-2023, 01:41 AM
Replies 53
Views 7,118
18-10-2021, 01:04 AM
Replies 18
Views 1,192
03-04-2021, 03:13 PM
Replies 48
Views 2,941
07-10-2020, 03:06 AM
Last Post by Stoney
Views 753
28-08-2020, 02:46 AM
Last Post by iceman
Replies 565
Views 21,805
22-04-2020, 06:15 AM
Last Post by purplewitch
Replies 86
Views 3,885
22-02-2020, 03:05 AM
Last Post by paddywak
Views 752
05-12-2018, 01:29 AM
Last Post by IanS200
Replies 41
Views 3,017
18-12-2017, 08:23 AM
Last Post by Dark Samurai
