JapCarForum Cars, Cars, Cars! Project Cars MR2 GTi-16
MR2 GTi-16
MR2 GTi-16
Pages (20): Previous 113 14 15 16 1720 Next
Fozzy
26-03-2017, 01:15 AM
Cheers matey very helpful. I tried to give rep, but apparently i cant keep giving rep to the same person!
Is there a particular order to do a bleed, i did it LR, RF, RR, LF.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
26-03-2017, 01:15 AM #142
26-03-2017, 01:20 AM
I think my rep might be limited anyway due to not being paid up Wink Either that or you can only rep a person once per thread?
Anyway, unless you have ABS it doesn't have a specified order, in which case you do what you do on any hydraulic system and start with the one furthest away from the master cylinder, working your way towards it. So passenger rear first, then driver's rear, then passenger front, then driver's front. The pre '97 braking system is amazingly basic so nothing clever going on WRT bleeding.
26-03-2017, 01:20 AM #143
26-03-2017, 01:23 AM
Hurrican i have given a rep to Toxo for you as i can see how much he has helped:thumbup1:
26-03-2017, 01:23 AM #144
26-03-2017, 01:25 AM
Lexusboy Hurrican i have given a rep to Toxo for you as i can see how much he has helped:thumbup1:
Cheers Ian Wink 71 points now! I will pay up one of these days I promise... owning an MR2 Turbo is a wallet rinsing way of life!
26-03-2017, 01:25 AM #145
Fozzy
26-03-2017, 01:36 AM
I have ABS on my car.
I cant wait until i fit a turbo lump, its far too cheap to run at the minute!!! Cheers for that Ian, have some rep yourself
Fozzy
26-03-2017, 01:36 AM #146
26-03-2017, 01:51 AM
Hurricane I have ABS on my car.
Bleed procedure is the same as it's pre 97.
Hurricane I cant wait until i fit a turbo lump, its far too cheap to run at the minute!!! Cheers for that Ian, have some rep yourself
Is that your longterm plan then, to do a turbo conversion?
26-03-2017, 01:51 AM #147
Fozzy
26-03-2017, 02:06 AM
Well im happy with it for now, but im sure ill get bored of the power at some point. My aim for this year is just to enjoy it and get it looking a bit tidier. The bodywork isnt great, but it should tidy up quite well.
It really depends on whether i can afford it at the end of the day. I would love to turbo it, and if i do ill try and get a complete rear clip so its as simple a possible.
Fozzy
26-03-2017, 02:06 AM #148
26-03-2017, 06:16 AM
Nice one Pete, but we need pics ! :thumbup:
26-03-2017, 06:16 AM #149
Fozzy
01-04-2017, 10:08 AM
Ok so to start off, a couple of pics of the car. I was off work on monday with a bad shoulder, so i took the oppertunity to give the car a wash. I also gave it a go with a clay bar. Makes a hell of a difference, im impressed.
But typically as british weather goes, it started to rain a little, so i got a couple of pics of the beading...... little things......
[Image: DSC00645.jpg]
[Image: DSC00646.jpg]
[Image: DSC00648.jpg]
[Image: DSC00649.jpg]
[Image: DSC00650.jpg]
Fozzy
01-04-2017, 10:08 AM #150
 10 Guest(s)
 10 Guest(s)
