My new toys
My new toys
I can't say I ever remember having a noticeable wobble with the IS200, but none of my suspension set up was standard.
They do look cool though.
el_bandido I can't say I ever remember having a noticeable wobble with the IS200, but none of my suspension set up was standard.
Looking nice and new. I like
Ooo... Nice diff mounts.
Those 3x 12mm Allen key bolts are a ****** to get out...
Need to see a few pics when done
FOSSIL FUELS Ooo... Nice diff mounts.
Well I fitted the Weld semi rigid diff bushes. Fossil you were partly correct, the allen bolts were easy to remove but a pain to be mounted again together with the bushes. It took a lot of time and a few scratched on the Weld bushes to have them on. Best option is to remove the diff all together and work on the bench and not under the car. Here are some pics of the parts fitted on the diff.
Now the ride is more repsonsive during acceleration. There is a feel of better repsonse when you hammer the throttle. The cons side is the noise generated from the diff when you leave the foot from the throttle, but do not imaging it is very loud...it would not affect the joy of ride during cruising. I believe it is something you prepared to have in a fully modified car.
might have to invest in some of them mate!
Well the TRD door stabilizers are on. I am not sure if there is significant improvement on my car since the chassis was already stiff prior. I can only say that you need a bit more force to close the door and it improves the looks when you open the door.
