JapCarForum General Discussions The JCF Lounge Is200 vs is300
Is200 vs is300
Is200 vs is300
14-03-2019, 05:52 AM
The IS300 is the better car. I own an IS200 and will be buying an IS300 to tune. There is A LOT of information and gear out there for the 2JZ engine. The 1G-FE in the IS200 will probably be 2 or 3 times as expensive in terms of £ for horsepower and it's a worse engine than the 2JZ to begin with.
Also, an NA IS300 kicks out about the same power as a supercharged IS200, which will set you back £2k + just for the SC kit. Easy maths to be honest.
In terms of differences, the IS300 has a different back end configuration. Someone might have to correct me here, but the IS300 diff has a much bigger pumpkin than the IS200. Never looked under both to check though.
Also: The headlight cluster is slightly different if you have the HID fitted IS300.
Edited 24-04-2012, 03:27 PM by el_bandido.
14-03-2019, 05:52 AM #11
Nuttaomen
14-03-2019, 07:02 AM
Dino think ur gonna be my best mate
The 300 look better
Nuttaomen
14-03-2019, 07:02 AM #12
The 300 look better
14-03-2019, 07:17 AM
The is200 and 300 are visibly identical :p
14-03-2019, 07:17 AM #13
Nuttaomen
14-03-2019, 07:26 AM
el_bandido The is200 and 300 are visibly identical :p
A smart one is see Tongue
Nuttaomen
14-03-2019, 07:26 AM #14
14-03-2019, 07:42 AM
I'm not even going to say sorry for that one, you will get used to it on this forum Big Grin
For some reason, insurance on an IS300 also seems to be cheaper than a 200.
14-03-2019, 07:42 AM #15
14-03-2019, 07:43 AM
Nuttaomen Dino think ur gonna be my best mate
The 300 look better
always here to help if i can dude
14-03-2019, 07:43 AM #16
The 300 look better
Nuttaomen
14-03-2019, 07:49 AM
el_bandido I'm not even going to say sorry for that one, you will get used to it on this forum Big Grin
No need I'll give u that one till next time :p
The insurance is covered as family traders policy Smile
Nuttaomen
14-03-2019, 07:49 AM #17
mattlaw
14-03-2019, 11:11 AM
Dino from what I've read you can turbo the 300 without lowering the compression ratio aslong as you keep the boost level low
mattlaw
14-03-2019, 11:11 AM #18
14-03-2019, 11:30 AM
mattlaw Dino from what I've read you can turbo the 300 without lowering the compression ratio aslong as you keep the boost level low
Even when you do want to go a bit higher, you can put a TT head gasket on and up the boost a little. Safer to change the pistons though. 2JZ engines really are amazing bits of kit.
14-03-2019, 11:30 AM #19
14-03-2019, 12:19 PM
yes you are correct in what youve read the magic number the americans use is 7psi and under to be safe on ge internals, anything above and your playing with fire really
14-03-2019, 12:19 PM #20
Replies 40
Views 1,516
19-01-2020, 09:33 AM
Last Post by S
Views 674
27-12-2019, 02:25 PM
Last Post by big_echo
Views 339
26-07-2019, 02:10 PM
Last Post by lexuslloyd
Replies 49
Views 2,651
29-04-2019, 02:23 AM
Views 314
04-01-2019, 05:29 AM
Replies 24
Views 1,141
17-12-2018, 10:54 AM
Last Post by Barry
Views 338
13-09-2018, 03:56 AM
Last Post by Lexuslady
Views 465
12-06-2018, 11:35 AM
Last Post by jimxms
Views 502
18-05-2018, 02:30 AM
