JapCarForum Cars, Cars, Cars! General Car Maintenance '04 Lexus SC430 Oxygen sensor replacement
14-04-2019, 12:53 PM
The PDF tells you which bank 1 sensor 1 is. Driver's side/Passenger side isn't a good way of working it out because yours is different to ours! Smile Although your car has a 3UZ-FE engine which isn't directly listed, it WILL be the same as a 2UZ-FE.
I don't think the one right behind it is likely to fail because there is a catalytic converter inbetween them. Presuming they are talking about the same bank, sensor 2, rather than bank 2 sensor 1.
Edited 25-05-2012, 10:41 PM by toxo.
14-04-2019, 12:53 PM #11
mattlaw
14-04-2019, 01:42 PM
Just do the 1 that needs it pal,
mattlaw
14-04-2019, 01:42 PM #12
cth
28-04-2019, 05:24 PM
When I attempted to replace the sensor, I apparently was not able to locate the upstream location of S1/B1 - The only sensor I located (just one on the left or right side) was right under the front seat floor pans, & I didn't see any other sensor location...? Those sensors have a longer wire assembly (10-12 inches) then what I was given as the S1/B1, which has a 6-8 inch wire. I'm not able to locate the upstream sensor. Help!
cth
28-04-2019, 05:24 PM #13
mattlaw
28-04-2019, 10:26 PM
Just follow the exhausts, it's passenger side at the front, if your lying underneath the car follow the exhaust down from the manifold and you can't miss it, unfortunately that ones a bit of a tw@ to unplug
mattlaw
28-04-2019, 10:26 PM #14
mattlaw
28-04-2019, 10:30 PM
Hold on your in the states, it'll be drivers side, forgot your steering wheel is on the wrong side
mattlaw
28-04-2019, 10:30 PM #15
29-04-2019, 02:53 AM
Have a look at this:
[Image: Lexus_CalSciCtr_1UZ-FE_V8_exhibit.jpg]
That's an older engine than yours but the O2 sensors are in the same place. The sensor is in the underside of the exhaust manifold, just after all 4 branches meet up into 1 pipe. Both sides of the engine are the same.
Edited 09-06-2012, 12:27 PM by toxo.
29-04-2019, 02:53 AM #16
Views 339
09-11-2023, 11:04 AM
Last Post by Keeperlit19
Views 988
07-12-2021, 09:23 AM
Last Post by reganlives
Views 1,504
09-11-2021, 02:37 AM
Last Post by Dinho
Views 865
28-01-2021, 06:18 AM
Last Post by 1374lee
Views 889
29-08-2020, 11:20 AM
Views 568
03-05-2019, 11:23 PM
Views 768
19-10-2018, 02:01 PM
Replies 18
Views 1,564
24-11-2017, 07:13 PM
Last Post by D6NGR..
Views 11,356
09-09-2017, 12:26 PM
Views 1,093
17-07-2017, 02:02 PM
