JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications 140mm Pulley with Blackbox/FCD
01-05-2019, 01:48 PM
Yeah but that could make one set too rich, or too lean trying to compensate for the bad gas from the other set.
01-05-2019, 01:48 PM #11
mattlaw
01-05-2019, 01:51 PM
No if you wire them together it'll only read from one bank, eg if you wire b1s1 into b2s1 the ecu will only receive readings for cylinders 4,5,6
mattlaw
01-05-2019, 01:51 PM #12
01-05-2019, 10:31 PM
No Matt he means fitting one O2 sensor after the cat, then sending that signal to both banks on the ecu. 1 sensor, 2 connections. Not 2 sensors 1 connection.
01-05-2019, 10:31 PM #13
Jon
02-05-2019, 08:15 AM
thanks guys, that'll give me something to think about for a while.
I might have to do some experimenting when I get an AFR gauge.
Stav, how much are them O2 simulators you sell, or are they easy to make?
Jon
02-05-2019, 08:15 AM #14
02-05-2019, 10:23 AM
Their not difficult to make mate if you have the correct wiring diagram. I sell them for £40.
Stav
02-05-2019, 10:23 AM #15
Stav
buzzard2011
06-05-2019, 11:40 AM
hi,
just like to say im running a 138mm pulley and have no probs with a fcd,maybee a tad lean when redlining,but i dont get there that often as im getting aged:lol:
anyway,im running a switched charger,or should i say was,im gonna have to fit a bypass as there is too much restriction through the charger itself when switched off.
i was thinking of getting a electronic throttle body and wiring that up so when the charger is switced on the n/a air flow is shut of but dont know if that would screw up the fueling.
cheers.
buzzard2011
06-05-2019, 11:40 AM #16
hi,
cheers.
Jon
07-05-2019, 03:40 AM
buzzard2011 hi,
cheers.
Im sort of in the same situation, apart from it running lean when redlining - with the decat, when redlining/gear change at high RPMs, people following have said I get flames out of my exhaust, which I would presume is over fueling?
Anyway, how do you find the switched charger? How are you switching yours? Mine is on a microswitch on the throttle body which is in series with a 'master' switch on the dash - which is good when you have your foot down, but the ECU doesnt like it if you try to drive 'normally', which gets me onto the restriction - Im the same as you, there is a slight restriction over standard when the charger is 'off' but, since i'm wanting to drive sensibly anyway, the restriction doesnt bother me.
Ive just got a bypass valve from a Mini Cooper S, which I should be fitting soon, so i'll see how well that works.
Last question, whats your pulley off? Any pictures etc?
Jon
07-05-2019, 03:40 AM #17
buzzard2011 hi,
cheers.
buzzard2011
07-05-2019, 04:40 AM
ive got mine on a switch on my gear knob,just push on/off,like you its fine when boosting but a bit of a struggle when off,i was looking at a mini bypass myself,but wanted a electronic bypass so when i turned the charger on the air switches,and hopefully when off ill have no airflow restriction.if that doesnt work ill go down the vaccuum bypass route and try that.
i got a pulley from a merc,had to redrill the holes though,but not a problem,
i have pics somewhere i think ill post some later.
buzzard2011
07-05-2019, 04:40 AM #18
buzzard2011
07-05-2019, 04:44 AM
this pulley.MERCEDES BENZ: 6032050110
buzzard2011
07-05-2019, 04:44 AM #19
Talisker
17-06-2019, 12:42 AM
In post #7 Dimis mentioned using 215cc injectors from a Toyota Tacoma. Does anyone have any idea what part number that would be or even what they look like? Ebay searches return quite a few results but the injectors all look different. I'd hate to spend out quite a lot to find I've got the wrong injectors.
Talisker
17-06-2019, 12:42 AM #20
Views 710
23-05-2023, 12:26 AM
Last Post by ashj25839
Replies 168
Views 6,917
03-07-2022, 02:56 AM
Views 282
01-07-2022, 12:38 PM
Last Post by lexusdaydreaming
Views 476
14-09-2021, 07:43 AM
Last Post by P.Lindblom
Views 353
26-07-2021, 11:20 AM
Last Post by reganlives
Views 333
13-03-2021, 05:38 PM
Last Post by deccie22
Views 529
17-09-2020, 03:53 PM
Last Post by gsitlv
Views 683
05-09-2020, 12:06 AM
Views 298
02-06-2020, 01:57 AM
Replies 59
Views 3,668
21-06-2019, 10:05 AM
Last Post by buzzard2011
