JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Tezza supercharger
Tezza supercharger
Tezza supercharger
03-08-2019, 01:56 AM
Ah I see. When the MK1 MR2 guys fit larger pulleys to their superchargers they have to use a ford idler. So I guess you will have to try a few and see where you end up! At least from that picture you know it's marginally smaller than the alternator pulley.
03-08-2019, 01:56 AM #11
mike_01
03-08-2019, 02:07 AM
Ah might be worth looking at, still with the 3s-ge engine so may fit mine, do you know what model, escort maybe?
mike_01
03-08-2019, 02:07 AM #12
03-08-2019, 02:27 AM
Nah MK1 MR2 is a 4A not a 3S. Also I made a mistake. It seems the enlarged pulley suppliers provide a ford pulley which is a piece of **** and falls to pieces, the recommended replacement is from a V6 camry. They use the top timing belt idler. Its ~60mm I believe (maybe 63?)
Edit: Found this.
Camry idler is 62mm diameter
40mm deep (wide?)
Mounting hole = 12mm diameter
"The Camry idler is very solid looking, and also benefits from having a 30mm diameter recess for the socket makes socket access easier....... "
Edited 13-09-2012, 12:04 PM by toxo.
03-08-2019, 02:27 AM #13
Edit: Found this.
40mm deep (wide?)
mike_01
03-08-2019, 02:39 AM
Will look into them, go to my local part's and see what it looks like, cheers
mike_01
03-08-2019, 02:39 AM #14
S
03-08-2019, 02:58 AM
Nice to see you seem to be getting sorted mate!
S
03-08-2019, 02:58 AM #15
mike_01
09-08-2019, 02:00 AM
Right getting somewhere, got an alternator cheap off ebay so did a quick mock up waiting for bearing to come and will get some pictures up :biggrin:
mike_01
09-08-2019, 02:00 AM #16
Views 1,667
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 710
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 468
06-04-2023, 02:00 AM
Replies 24
Views 909
12-01-2023, 11:53 AM
Views 109
03-01-2023, 01:19 PM
Views 85
27-12-2022, 10:58 PM
Views 406
02-12-2022, 01:57 PM
Views 417
04-11-2022, 05:54 AM
Views 58
30-07-2022, 01:49 PM
