JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Need some help pricing up some work on my is200
Lewed_is200
10-12-2019, 01:14 PM
FirebirdPhil If you use a brake like clamp (as you should) then remove the calliper you will probably get away without bleeding the system. Some people use a mole-grip instead of a dedicated clamp, just be careful about how much pressure you apply. Its an easy job on the IS200.
So if I was to clamp the hose then remove the old caliper would I have to fill the new caliper up with brake fluid then refit that would be ok or would I still need to bleed to make sure there's no air in the system?
Lewed_is200
10-12-2019, 01:14 PM #11
10-12-2019, 01:21 PM
Fit the new calliper and when its all back together take the fluid cap off make sure there is plenty of fluid in there, fully open the bleed screw and then take the line clamp off, gravity will bleed it for you, done this many times and never once had to bleed the entire system. A Saab tech showed me this method, it works, its simple and free.
Whenever doing break jobs use a line clamp, this stops the worst fluid in your system going up into the master cylinder.
10-12-2019, 01:21 PM #12
10-12-2019, 01:40 PM
dont use clamps if you have aftermarket braided steel lines you could damage them
10-12-2019, 01:40 PM #13
Lewed_is200
11-12-2019, 03:06 AM
Will this clamp be ok?
120972806643
Lewed_is200
11-12-2019, 03:06 AM #14
120972806643
11-12-2019, 10:16 AM
Not used them so I can't comment either way.
11-12-2019, 10:16 AM #15
11-12-2019, 10:45 AM
I would say that's a bit OTT, any car shop (halfords) sell brake line clamps I have 2 types a metal version and a plastic one, just what I've got over the years both do a great job
11-12-2019, 10:45 AM #16
Views 329
13-12-2023, 02:06 PM
Views 470
09-11-2023, 03:46 AM
Last Post by Dinho
Views 700
06-11-2022, 01:49 AM
Views 1,185
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,148
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 459
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,723
04-08-2021, 04:34 AM
Last Post by cjoseph
