JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Stage 2 Supercharger upgrade
reganlives
28-05-2020, 08:11 AM
Also before I fit it I'm guessing I should change the oil on the charger? Is there anything else I need to look out for or check?
reganlives
28-05-2020, 08:11 AM #11
rob
29-05-2020, 09:32 PM
Yep replace the oil, should be quite clean when it comes out.
Glue a magnet to the drain plug if u wish. Check there isn't any play in the rotors - forward rear movement in the pulley and also wear in the pulley bearing.
If it has the original 3 small bolts on the pulley drive use larger bolts.
rob
29-05-2020, 09:32 PM #12
reganlives
31-05-2020, 12:30 AM
Why should I replace the bolts mate? Also how should I check for play in the rotors? Should they not move at all other then move round like they do?
reganlives
31-05-2020, 12:30 AM #13
03-06-2020, 01:34 PM
Would definitely change the bolts. 2 of mine snapped but lucky got them out fairly easily and replaced them - searched every trader at JAE for new bolts and eventually found a box of hundreds in Rabster's boot!
As far as power Dimis is getting about 270bhp now with a 160mm pulley, bigger injectors and a good map, (manifold and decat exhaust system etc. too) but I think this is about the most you can hope for. A remap is always recommended, just to get the fueling perfect. A wideband is a must if you are concerned about the fueling at all (without a perfect map then you should be concerned) as some people (naming no names!) have bent rods etc. with this spec badly set up!
As far as the black box, I think the Emanage can replace it's function, but not 100% sure.
I think Popeye is a member on here but unsure of his username, he is currently doing the same upgrades, and I believe is going to fit injectors from a 1.8L 4 cylinder Avensis.
03-06-2020, 01:34 PM #14
reganlives
04-06-2020, 01:47 AM
Thanks for the response Stoney. I'm looking at getting the car mapped at tuning developments in Warrington. I've noticed that a lot of people on the startlet club have used these and they tend to do a lot of Toyota's but not sure on their overall knowledge, are they a decent company to use? They are charging £250 for the mapping plus extra if I want them to fit the emanage. I haven't got an uprated exhaust on the car yet as prefer the standard one really. Would I be ok with this though? I'll probably upgrade the exhaust at a later date.
As for the bolts, which size will I need?
reganlives
04-06-2020, 01:47 AM #15
reganlives
04-06-2020, 01:49 AM
Stoney, as long as the car has been mapped well should it remain as reliable as stock I presume? This is the first car that I'm charging that's why so still learning!
reganlives
04-06-2020, 01:49 AM #16
04-06-2020, 03:01 AM
reganlives Stoney, as long as the car has been mapped well should it remain as reliable as stock I presume? This is the first car that I'm charging that's why so still learning!
I think it is better to remove the precats if you have not done that yet and also fit a sport catalyst. If you do not do any of these two upgrades your catalysts will collapse soon or at worst case scenario melt them due to higher exhaust temperatures that you will have with the stage 2 upgrade pulley. Also your car performance, (torque etc) will be killed from your oem exhaust system. Not worth upgrading to a stage 2 pulley without upgrading your exhaust system. From 155hp you will raise to around 250hp. 100hp increase without exhaust upgrade??? what do you think it will happen?
04-06-2020, 03:01 AM #17
04-06-2020, 03:13 AM
Get a backbox designed for turbo applications. The Subaru impreza ones fit on with a little cutting and welding.
04-06-2020, 03:13 AM #18
reganlives
04-06-2020, 04:13 AM
Thanks for the input guys...looks like this is going to end up costing a lot more than I thought! So what if I were to just use a standard pulley? I know that this would leave me with less power but where would I stand then? Dimis, would I still need to carry out the exhaust mods you mentioned etc?
reganlives
04-06-2020, 04:13 AM #19
04-06-2020, 04:39 AM
one thing ive learnt from people who have done similar projects is to take the total cost of what you think it will cost, then double or tripple your original figure and you should just have enough to cover the costs.
04-06-2020, 04:39 AM #20
Views 1,677
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 723
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 470
06-04-2023, 02:00 AM
Replies 24
Views 931
12-01-2023, 11:53 AM
Views 111
03-01-2023, 01:19 PM
Views 86
27-12-2022, 10:58 PM
Views 410
02-12-2022, 01:57 PM
Views 424
04-11-2022, 05:54 AM
Views 58
30-07-2022, 01:49 PM
