JapCarForum Trade Area Wanted is300 auto to manual conversion parts
24-09-2020, 10:40 PM
youll need the clutch pedal, and the clutch cylinder, plus prob new mount for gearbox
24-09-2020, 10:40 PM #11
24-09-2020, 11:44 PM
john wan Would think youd need the geat gator maybe surrounding plastics also the plate that bolts onto the chassis with the rubber gator
Sparkystav youll need the clutch pedal, and the clutch cylinder, plus prob new mount for gearbox
cheers boys Smile
ive been reading through this list off of my.is http://my.is/forums/f114/6-speed-all-inf...nd-410664/
the transmission mount i would like to use a TRD one from suprastore
http://www.suprastore.com/trdtrmotosu6.html or if i can get it more local would be better
SRT do some Billet Shifter Bracket for V160 and a shift rod for $350 these line up the shifter to the centre of the tunnel hole
http://www.swiftracing.com/SRT/item.aspx...&u=1000044
http://www.swiftracing.com/SRT/item.aspx?id=45
will possibly need to find a Transmission Crossmember it says SRT use to make an already modified one but i cant find them listed on the site anymore so may have to find one and get it fabricated or modified to fit
the slave and master cylinders i will probably get new ones from toyota. and use the the proper supra TT ones rather than ones fom a 200.
flywheel bolts are about £30 best to get some new ones i think just in case
John well done mate for reminding me about the geargaiter and surounds it would be easier just to swap for a 200 one these are on ebay fairly regulary
so its just a clutch assembly to track down
how easy is it to remove all the clutch ped assembly and fit it? :confused:
drive shaft either import one from a toyota sequiola 4x4 or get one custom made?
and a rear end diff will need one that has a 3.2 ish ratio that will need to be found at some point
:eek:
Edited 06-11-2013, 09:52 AM by is300_dino.
24-09-2020, 11:44 PM #12
cheers boys Smile
:eek:
26-09-2020, 02:22 AM
Do you need the transmission tunnel from a manual like you do when converting a MKIV Supra?
If you need any parts direct from Toyota let me know :thumbup1:
I also have a JZX90 rear gearbox mount & crossmember which is compatible with LOADS of cars, it's got them all written on it so I will have a look.
26-09-2020, 02:22 AM #13
26-09-2020, 02:35 AM
I looked on the parts catalogue, the tunnel itself is the same but the top metal piece that has the shifter hole in is different.
Part number for auto is 58261-53030
Part number for manual is 58261-53010 (01/1999 - 03/2001)
58261-53011 (07/2001 - )
It's about £120 for the part so you're better off gas axing it off another car or taking a hammer to yours!!
26-09-2020, 02:35 AM #14
26-09-2020, 03:20 AM
the tunnels should be ok as it is, from what ive read lol, if i can get the SRT Shifter Bracket and shift rod it aligns the stick to pop up in the centre of the tunnel hole, if not im going to have to try and get some fabricated Sad then its just a case of getting an alloy sheet to cover the hole, if ive understood it all properly.
i dont think the box im getting has any of the mounts/crossmember bars so yeah if you could have a look and see how compatible it would be will be great thank you Smile
whats the prices on the master and slave cylinder kits from a tt6?
also sequiola 4x4 drive shafts are they available from toyota uk? what is a sequiola called in the euro market if at all they were available?
Edited 07-11-2013, 12:57 PM by is300_dino.
26-09-2020, 03:20 AM #15
26-09-2020, 03:32 AM
Do you want a master from a TT6 or an IS200? As that's the bit that needs to attach to the bulkhead and the pedals...
Sequiola is LHD only but I can get prices for parts if you *really* want...
26-09-2020, 03:32 AM #16
26-09-2020, 03:33 AM
are these parts still available john?
90947-ja800 TRD clutch hose
12371-ja800 TRD 6spd trans mount (ive heard these have stronger rubbers?)
26-09-2020, 03:33 AM #17
26-09-2020, 03:37 AM
I can't order TRD parts mate, you can only get those through TRD distributors. So in this country you're stuck with Fensport and their 50% markup. Or you can import from the US.
26-09-2020, 03:37 AM #18
26-09-2020, 03:38 AM
master from a tt6 is probably better i would of thought?
the rear drive shaft from the sequiola is an apparent direct fit in length and couplings to match up between the v160 and the diff few people in the us have used these shafts. would them being LHD be an issue??
26-09-2020, 03:38 AM #19
26-09-2020, 03:39 AM
toxo I can't order TRD parts mate, you can only get those through TRD distributors. So in this country you're stuck with Fensport and their 50% markup. Or you can import from the US.
no worries thanks Smile
26-09-2020, 03:39 AM #20
Views 272
27-12-2023, 08:10 AM
Views 111
25-10-2023, 07:20 AM
Last Post by Jimbob-T-Lex
Views 135
05-10-2023, 07:06 AM
Last Post by TWIN..TURBO..DAN.
Views 123
23-02-2023, 02:56 PM
Last Post by Luke200
Views 234
24-01-2023, 12:55 PM
Views 138
02-05-2022, 06:31 AM
Last Post by P.Lindblom
Views 91
13-12-2021, 03:43 PM
Last Post by spud1973
Views 396
26-11-2020, 10:48 AM
Views 412
01-10-2020, 03:49 PM
Last Post by Stoney
Views 128
14-09-2020, 02:54 AM
Last Post by sprinter2012
