JapCarForum Car Manufacturers Toyota Bought a 3 door Rav4.
uncle bob
25-02-2021, 01:39 AM
Phil01 What a load of ****, Bob carry on using coppaslip, I use it as well on my studs and been doing it in the motor trade for umpteen years and never had a nut come loose due to incorrect torque, and at least you know the nut will undo at the side of the road when its pissing down with rain doing a wheel change
Although I'm no longer in the trade ,I used it for over 20 years in my job without any problems, and have used it for 10 years since on my own cars, I do respect other peoples opinions but I will carry on to use it ,thank you for backing me up on this debate Smile
uncle bob
25-02-2021, 01:39 AM #11
rob
25-02-2021, 08:28 AM
who mentioned anything about nuts or bolts coming loose, I cant see that, did I miss it somewhere?
rob
25-02-2021, 08:28 AM #12
Phil01
27-02-2021, 05:29 PM
Friction on the stud has nothing to do with it, it is the final clamping force that is what is reqd
Phil01
27-02-2021, 05:29 PM #13
rob
27-02-2021, 11:22 PM
Im not trying to force or preach to anyone to change habits even If I think it is right or wrong.
Just people should be aware that lubricated studs or nuts will result in an over stretched stud or bolt compared to a dry stud or bolt for the same torque figure.
Phil how is the torque achieved. . What does the nut or bolt actually act against once it contacted the mounting face.. the threads, so if lubricated the force (torque) required to further turn the nut bolt is less. More turns more stretch, we don't measure clamping force, if we did then its all moot.
If you see what I mean?
I work all day with critical torques some down to a 0.10% tolerance . The differences in stretch between lubed and non lubed can be measured.
Anyway said my bit so have a nice sunny day in your part of the world where ever that may be. Wink
rob
27-02-2021, 11:22 PM #14
Phil01
01-03-2021, 04:11 AM
Actually the stud/nut is not that critical unless you are a baboon, it can be anywhere from the force of a woman using the supplied wheel nut wrench with such a low leverage ratio right up to a monster idiot using a breaker bar.
You too Rob, have a great day mate
Phil01
01-03-2021, 04:11 AM #15
rob
01-03-2021, 10:23 AM
24c today meant to be 26 tomorrow bbq primed and ready ! Big Grin:thumbup:
rob
01-03-2021, 10:23 AM #16
Views 990
31-03-2018, 06:01 AM
Last Post by Voodoo Vix
Views 618
13-12-2017, 11:53 AM
Last Post by kevinsgs300
Views 877
03-07-2016, 09:35 AM
Last Post by TM
