JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications need help with supercharger issue
beamstezza
07-01-2023, 07:19 AM
the mini bypass is fine they all make that noise on the is200 setup your tensionor looks way off id say the plate way not aligned properly when made but i would still try fitting a new tensionor to check alignment
beamstezza
07-01-2023, 07:19 AM #12
196
07-01-2023, 08:31 AM
I looked at it again on its the whole charged thats off, but u think i found problem 3 bolts on charger not 4 so its kicked it out a bit and a garage put a metal plate on engine to frame to strengthen it as it was shaking probably due to the 4th bolt missing. Am fix it as the bolt was shered ane stuck in frame. But then saying this it doesnt matter if supercharger is out of line because uts the tensionr on frame that is out of line, i used ny old tensioner to realine it and its same still way off. Id prefer to get a new frame while am here to make sure, do you know anyone who makes them.
lexusdaydreaming
07-01-2023, 08:31 AM #13
beamstezza
07-01-2023, 09:48 AM
why dont you bring it to some you be line up the plate that holds the tensioner this would be an easy job
beamstezza
07-01-2023, 09:48 AM #14
beamstezza
07-01-2023, 09:50 AM
why dont you bring it to someone to line up the plate that holds the tensioner this would be an easy job
beamstezza
07-01-2023, 09:50 AM #15
196
07-01-2023, 10:01 AM
its finding someone and having car off road that is the problem if am taking it off id rather get new frame, but its a good idea, all try find someone that can do it in a day n strip it of that morning.
lexusdaydreaming
07-01-2023, 10:01 AM #16
196
07-01-2023, 10:04 AM
i have uploaded a picture of a new frame i found on-line and the part where tensioner goes on looks thicker which makes me think mine is poorly made as my panel is thinner and closer to frame than should be.
lexusdaydreaming
07-01-2023, 10:04 AM #17
beamstezza
07-01-2023, 10:14 AM
you would need to leave it on the car so that they could align it off the other pulleys or if you or a mate weld it wouldn't be a hard job
beamstezza
07-01-2023, 10:14 AM #18
07-01-2023, 11:19 AM
I loan a jig that is a direct copy of the TTE cradle it's made 12 or so DIY builds so far and I've had mine on since before JAE 2014 that was kit number 1.
U could try a washer under the corner of that tensioner to pull it straight just to see if that makes a difference
07-01-2023, 11:19 AM #19
08-01-2023, 11:55 AM
Do you have a cradle for sale? I dont know what you mean?, yea i was thinking of a washer type plate but if it slipped out it would snap belt again. Getting great ideas from you guys thanks
lexusdaydreaming
08-01-2023, 11:55 AM #20
Views 1,897
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 824
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 513
06-04-2023, 02:00 AM
Views 176
03-01-2023, 01:19 PM
Views 135
27-12-2022, 10:58 PM
Views 470
02-12-2022, 01:57 PM
Views 483
04-11-2022, 05:54 AM
Views 84
30-07-2022, 01:49 PM
Views 481
15-07-2022, 01:17 PM
