JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Problem with IS200 head unit
18-08-2016, 07:15 AM
parthiban I think he means the bit around the tape deck, on earlier cars it's a silvery gold colour, on later cars (post 04 i think) it's all black.
Ah yes, thanks, I get it now :biggrin:
18-08-2016, 07:15 AM #11
iLLzLex
18-08-2016, 07:17 AM
Yeah thats what i meant...its a shame...because i dont mind the ipod quality but still i wouldnt mind having 6cds...but the cd button does not even respond...and when i press eject nothing happens, when i press load it jus clicks inside for like 10 seconds then nothing happens...
iLLzLex
18-08-2016, 07:17 AM #12
18-08-2016, 07:19 AM
If it's a top-loading CD player then it's quite easy to remove it, take the cover off and free the discs, and this often (temporarily, at least), sorts the problem.
However if it's a bottom-loader then it's a nightmare to dissasemble and it's probably a terminal failure (unless a quick whack sorts it out lol).
18-08-2016, 07:19 AM #13
iLLzLex
18-08-2016, 07:21 AM
i cant remember off top off my head which 1 it is lol...but i'll take a pic when i get home.
iLLzLex
18-08-2016, 07:21 AM #14
kam05
18-08-2016, 07:30 AM
Which year is your IS200? Should be able to tell if you have a top loader or a bottom loading unit.
kam05
18-08-2016, 07:30 AM #15
iLLzLex
18-08-2016, 11:43 PM
kam05 which year is your is200? Should be able to tell if you have a top loader or a bottom loading unit.
2000 (x)
iLLzLex
18-08-2016, 11:43 PM #16
2000 (x)
kam05
18-08-2016, 11:52 PM
iLLzLex 2000 (x)
Late 2000 or early 2000?
Mines a late 2000 model (October) and it has a top loading CD unit. This has failed in the past (luckily my car was still under warranty when the CD unit failed- Lexus replaced it FOC).
kam05
18-08-2016, 11:52 PM #17
iLLzLex 2000 (x)
iLLzLex
18-08-2016, 11:56 PM
kam05 Late 2000 or early 2000?
i think its late 2000...it goes like this...trc and heat seater switches, radio channel buttons, tape hole, then its the cd slot
iLLzLex
18-08-2016, 11:56 PM #18
kam05
19-08-2016, 12:50 AM
iLLzLex i think its late 2000...it goes like this...trc and heat seater switches, radio channel buttons, tape hole, then its the cd slot
Sounds like a top loading unit to me.
kam05
19-08-2016, 12:50 AM #19
19-08-2016, 02:29 AM
If the CD slot is at the top, which it sounds like, then you may be in luck. It's pretty straightforward to remove the head unit, then you can open up the top and free any trapped CDs. You may well find that it works fine after that, and there's no need to replace it.
Wozza has a walkthrough for removing the head unit but it hasn't been posted up on here yet. I have a version in a Word document that I can email you if you PM me your email address.
19-08-2016, 02:29 AM #20
Views 662
30-09-2022, 11:42 AM
Views 1,193
22-05-2022, 12:25 PM
Views 870
29-04-2021, 08:30 AM
Replies 22
Views 2,009
13-05-2020, 06:41 AM
Last Post by iceman
Views 554
19-03-2020, 01:25 AM
Views 786
16-03-2020, 09:00 AM
Last Post by daz@likwidart
Replies 88
Views 19,704
26-01-2020, 06:18 AM
Last Post by iceman
Views 2,448
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 716
28-09-2019, 08:22 AM
