JapCarForum Cars, Cars, Cars! General Car Maintenance Mazda RX7 Generations..
21-10-2017, 08:16 AM
Yeah, they're both 13B rotary engines but that's about where the similarties end. It's like saying that a 1G-GTE MK3 supra and a 1G-FE IS200 have the same engine. The 7 has sequential twin turbos where the 8 doesn't as well.
They must be pretty confident because they extended the warranty on the RX8 to 8 years to 100,0000 miles.
Edited 02-12-2009, 12:05 PM by toxo.
21-10-2017, 08:16 AM #11
Bobby
21-10-2017, 08:26 AM
Please stop talking about engine failures & rebuilds on RX8's Confusedcared:Confusedcared:Confusedcared:Confusedcared:
Cheers
Bobby
Shy boys don't get sweeties.
Bobby
21-10-2017, 08:26 AM #12
Cheers
Bobby
21-10-2017, 09:31 AM
toxo Don't forget that they drink oil because they're meant to, it's not the engines failing that causes it. They just have rpm-activated oil squirters, same as the later Supra TT's and the supercharged Levins.
I don't know much about rotary engines, but surely having rpm-activated oil squirters just means the oil is moved around differently ? Oil is only going to disappear if it leaks out or it's burnt ?
21-10-2017, 09:31 AM #13
21-10-2017, 10:32 AM
Well yeah, the injectors inject into the combustion chamber so it gets burnt.
21-10-2017, 10:32 AM #14
21-10-2017, 10:34 AM
toxo Well yeah, the injectors inject into the combustion chamber so it gets burnt.
The oil squirts directly into the combustion chamber ? Well, that would certainly explain it drinking oil ! :ohmy:
21-10-2017, 10:34 AM #15
21-10-2017, 10:38 AM
The problem is inherent to the design of the rotary engine, they don't have a combustion 'chamber' as such, and the area where the combustion takes place changes in size and shape through the rotation of the rotor. This makes for a very complicated sealing system, and when people talk about the engines blowing up 9/10 it's the seals that have gone (they are a service item). So they throw loads of oil into the mix to try and keep everything lubricated and sealed up, and some of it gets burnt off.
21-10-2017, 10:38 AM #16
Views 3,665
06-12-2019, 06:47 AM
Last Post by speedview
Views 3,004
09-09-2019, 11:03 AM
Last Post by Jaminglish
Views 1,348
15-12-2018, 09:48 AM
Last Post by Mikey
Views 4,020
09-07-2018, 12:11 PM
Last Post by Bobby
Views 1,209
07-05-2018, 09:36 AM
Replies 76
Views 7,983
29-04-2018, 05:56 PM
Last Post by ormi
Views 2,657
01-04-2018, 08:52 AM
Last Post by Mikey
Views 1,391
10-02-2018, 04:57 AM
Last Post by abactus
Views 1,041
18-01-2018, 06:13 AM
Last Post by Bobby
Views 2,378
22-05-2017, 06:09 PM
Last Post by wheels-inmotion
