JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Advice of fitting an Aftermarket Stereo to IS200 S Model
25-11-2016, 11:55 AM
You can easily connect up the relevant cable from the head unit to one of the bolts underneath the gear surround (which you'll need to remove). These bolts go straight into the chassis, so will be earthed. Connect the cable that they want you to connect to the handbrake to that, and you should be sorted.
25-11-2016, 11:55 AM #11
26-11-2016, 07:55 AM
Probably a bit late but there are a few 10mm bolts right behind the headunit, near the cross beam (big pipe behind dash) that i used and worked a treat for earthing out the brake wire? Big Grin
26-11-2016, 07:55 AM #12
Views 662
30-09-2022, 11:42 AM
Views 799
31-03-2020, 12:49 PM
Replies 88
Views 19,660
26-01-2020, 06:18 AM
Last Post by iceman
Views 2,438
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 715
28-09-2019, 08:22 AM
Views 423
17-09-2019, 11:52 AM
Views 331
04-09-2019, 11:50 PM
