JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Coil Pack going?
Coil Pack going?
Coil Pack going?
10-12-2016, 08:42 AM
So as per Stav's very helpful post here: http://www.outlawjapclub.co.uk/forum/sho...d.php?t=30
You'll be looking for one of these codes:
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
10-12-2016, 08:42 AM #11
russelllinn
10-12-2016, 09:22 AM
You are both right, there are four!! I didn't note the code then but if it comes back on will take it down to find out which one it is, what sort of money should I expect to pay you reckon?
cheers for all the info above, nice one :thumbup:
russelllinn
10-12-2016, 09:22 AM #12
10-12-2016, 09:24 AM
O2 sensors are expensive. The MR2 has 1 and it's like £180 if/when it goes. In the experience that I've seen aftermarket / pattern parts aren't worth it unfortunately.
10-12-2016, 09:24 AM #13
10-12-2016, 09:57 AM
There's a list of the IS300-specific codes >>here<<, including the likely causes.
As well as the sensor being at fault, there are also other possibilities indicated in those charts, but having said that I suspect that the sensor is most likely.
10-12-2016, 09:57 AM #14
russelllinn
10-12-2016, 11:00 AM
toxo O2 sensors are expensive. The MR2 has 1 and it's like £180 if/when it goes. In the experience that I've seen aftermarket / pattern parts aren't worth it unfortunately.
Huh that's no good, oh dear i'm sure i will be able to let you know as the light is back on, take it back tomorrow and see what the code is!!
steviewevie There's a list of the IS300-specific codes >>here<<, including the likely causes.
Thanks for the info Steve very informative, i'll be able to use that to see what it is :thumbup1:
russelllinn
10-12-2016, 11:00 AM #15
10-12-2016, 11:31 AM
The IS300 O2 sensors are roughly the same sort of price, I'm afraid. You might be able to get one cheaper though, if you do need one, from the US.
10-12-2016, 11:31 AM #16
russelllinn
10-12-2016, 11:35 AM
steviewevie The IS300 O2 sensors are roughly the same sort of price, I'm afraid. You might be able to get one cheaper though, if you do need one, from the US.
:crying: that's gonna eat into my Subaru fund then!! I'll see what the score is tomorrow hopefully and then see if cheaper in the US, cheers Steve.
russelllinn
10-12-2016, 11:35 AM #17
russelllinn
11-12-2016, 09:31 AM
Just got back from the garage and this is the code I have got come up, looks like that'll be my prob then, it's been fueling really bad too, used nearly quarter of a tank on 45 miles!!
Strange thing is though we unplugged the front sensor after resetting the code to try and throw another code up to double check which sensor it was and no code came up, now plugged it all back together and driven home and still no engine light, time will tell but don't wanna use it with it fueling like that!!
OEM part though £198 :blink:
russelllinn
11-12-2016, 09:31 AM #18
11-12-2016, 09:53 AM
Yeah it will eat fuel with a broken lambda sensor. Best get it replaced before you go through £198 of fuel Big Grin
PS PM me the part number if you've got it and I'll see what price I can get it for. Likely to be 15%-25% cheaper than retail.
11-12-2016, 09:53 AM #19
11-12-2016, 10:30 AM
That code is specifically showing that there's a malfunction in the heater circuit of the sensor (it heats it up to make it work properly). So that's more reliably showing that it is indeed the sensor compared to some other codes which involve the sensor (and possibly other things as well).
It's either the sensor, or the wiring to the ECU, or the ECU itself. By far the most likely cause is a failing sensor.
11-12-2016, 10:30 AM #20
Views 931
20-04-2017, 07:49 AM
