JapCarForum Trade Area Trade Archive Selling Archive IS200 TTE lowering springs
04-03-2017, 09:30 AM
Your right Steve there are a few different heights for the different spec/year IS, however regardless of this if your measurements above are with the springs on that is what the height of any IS would be
04-03-2017, 09:30 AM #11
04-03-2017, 02:08 PM
Yep I think the end point will be the same for any IS - and for a post 01 IS I think the drop will be about 30mm.
I might be interested in these, I know you only put these on recently, how long were they on the car for and how many miles have you done on them?
04-03-2017, 02:08 PM #12
04-03-2017, 09:05 PM
Yeap, 30mm is the max drop you will get with these, mine is a 2000 so I really noticed the difference from the stock springs!
04-03-2017, 09:05 PM #13
04-03-2017, 10:00 PM
They haven't done that many miles. I can dig out the receipts from when they were fitted and check, but for now I will have to take a total guess - 10K at most ? I can confirm later/tomorrow.
04-03-2017, 10:00 PM #14
deckie77
04-03-2017, 11:27 PM
steviewevie ok, I found my post. Measuring from the centre top of the wheel arch to the ground, my car was 63cm at the front and 66cm at the rear with no-one on board, no sub in boot etc. So with these springs I would expect any other car to be similar (I find it hard to imagine suspension mounting points etc would be different :confused1: )
That is pretty much the same height mine sit's at now, and mine was quite a bit lower than that before.
My car is alot more accessable to milti-storey's & speed bumps now at this height, so i wouldn't worry about it too much.
Get them bought!!!!!
deckie77
04-03-2017, 11:27 PM #15
04-03-2017, 11:33 PM
deckie77 That is pretty much the same height mine sit's at now, and mine was quite a bit lower than that before.
Yeah i have no problems with speed bumps, i ocasionally get a scrape if ive got people in the back, but no problems what so ever otherwise, IMO ride quality improved after i had them fitted:thumbup1:
04-03-2017, 11:33 PM #16
garyskisplym
05-03-2017, 06:40 AM
Am i right in thinking if i have a prefaceligt is sprt they are already lowered 10mm so will drop mine about another 25??
garyskisplym
05-03-2017, 06:40 AM #17
05-03-2017, 06:55 AM
Yes that is correct ^^^^^^^^^^
05-03-2017, 06:55 AM #18
05-03-2017, 07:02 AM
garyskisplym Am i right in thinking if i have a prefaceligt is sprt they are already lowered 10mm so will drop mine about another 25??
20mm, TTE are a 30mm dropSmile
05-03-2017, 07:02 AM #19
05-03-2017, 07:09 AM
Ooops duplicate post!
Edited 16-04-2010, 04:46 PM by SHAHZ.
05-03-2017, 07:09 AM #20
Views 283
05-05-2023, 03:10 AM
Views 1,241
06-09-2021, 04:01 AM
Last Post by KdotjapIS
Views 1,453
02-09-2021, 03:05 PM
Replies 40
Views 1,536
20-09-2020, 01:12 AM
Last Post by ozzie b
Views 207
17-09-2020, 12:35 AM
Views 306
06-09-2020, 05:51 AM
Views 161
02-09-2020, 12:49 PM
Views 220
23-08-2020, 10:16 AM
