JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Clunking When Braking
Demon
15-03-2017, 04:26 AM
I had this for about 2 years until i almost went mad!!!!!
Replaced the shims, pads, discs etc but the noise kept coming back. Finally i bought some used calipers from a LOC member and swapped them, been fine since..............however now i have a squeeling on the back thats driving me nuts. I give up with this car!
Hope you get this sorted soon mate.
Jason Big Grin
The 'Demon' is on its way :Shooting:
Now driving a Sh!tbox Sad
Smurf SOLD
Outlaw No: 016 Cool
Demon
15-03-2017, 04:26 AM #11
Jason Big Grin
Smurf SOLD
Outlaw No: 016 Cool
widnes_is200
15-03-2017, 09:42 AM
tommy i have 2 new rears if ure needing .in the bag unused if it helps
widnes_is200
15-03-2017, 09:42 AM #12
TommyH
15-03-2017, 10:29 AM
It's the front shims i need mate, but thanks alot for your offer.
TommyH
15-03-2017, 10:29 AM #13
widnes_is200
16-03-2017, 03:39 AM
check how many are missing , i have about 3 front second hand ones in the shed, topos and bottoms are different so check whats missing and ille see if its there mate,
widnes_is200
16-03-2017, 03:39 AM #14
TommyH
16-03-2017, 08:02 AM
I havn't had a chance to have a look mate, when i said it's the front shims, i ment thats where the noise was coming from. Would i need to take the caliper off to check the shims or can you see without removing ?
TommyH
16-03-2017, 08:02 AM #15
widnes_is200
16-03-2017, 09:21 AM
just take ure wheel off mate when i had 1 missing i took wheel off and u could move the pad up an down an see the shim missing, just went the scrappy, thats y i have a few spare, hope this helps
widnes_is200
16-03-2017, 09:21 AM #16
TommyH
16-03-2017, 11:30 AM
Thanks for the info mate, i'll give it a try tomorrow, weather permiting.
TommyH
16-03-2017, 11:30 AM #17
TommyH
18-03-2017, 04:26 AM
This clunking when turning slow and braking has retured to mines. It dissapeared after getting new pads about 4000 miles ago.
I took my wheels off today and checked the shims. Should you be able to slide the shims up and down slightly with a screwdriver ? or should they be soild onto your brakepad.
If solid i think i may try to put some copper slip on the shims.Would this help ?
TommyH
18-03-2017, 04:26 AM #18
TommyH
18-03-2017, 04:57 AM
Thanks for the info Gord, they are defo moving if i push them, so think i'll get copper slip on and hopefully that helps with the knocking mate.
Thanks again.
TommyH
18-03-2017, 04:57 AM #19
Thanks again.
TommyH
18-03-2017, 05:10 AM
Cheers mate, need to get this sorted.
TommyH
18-03-2017, 05:10 AM #20
 5 Guest(s)
 5 Guest(s)
