Eibach/TTE Anti Roll Bar Kit
garyskisplym Are hotchick good arbs??
Just fund a kit with lowering springs, sway bars and the bushs
is300_dino yes mate extremely brilliant! fitted mine 2 days ago see my early birthday present thread for an extra read
don't think you can buy uprated drop links for the is200??but unless your old ones are shot then theirs no point in replacing them...
garyskisplym Hi mate
Also where did you get your drop links from and would you recommend fitting uprated ones too
To be honest, the difference between any of the aftermarket uprated ARBs and the OEM ARBs is so big, it probably doesn't really matter which of those ARBs you go for. Any will make a huge difference and leave you with a big smile on your face !
The Blueprint/motor factors/eBay drop links are cheaper than OEM and should do the job fine.
