JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Drive flanges - what are they?
29-03-2017, 03:01 AM
I've just checked with Tony and those are the right parts. I think I need everything in the bottom pic, he said the bearings come as a kit, then the hubs, discs and pads.
@Steve do you have the part numbers that are required? So is everything in that bottom pic covered by 3 part numbers?
29-03-2017, 03:01 AM #11
29-03-2017, 03:09 AM
parthiban I've just checked with Tony and those are the right parts. I think I need everything in the bottom pic, he said the bearings come as a kit, then the hubs, discs and pads.
Why dont you get some mintex discs & pads, IIRC they are cheaper than the stock ones
29-03-2017, 03:09 AM #12
29-03-2017, 03:18 AM
SHAHZ Why dont you get some mintex discs & pads, IIRC they are cheaper than the stock ones
I've currently got ADL discs and mintex pads on, which were a little cheaper but I've had a problem of brake squeal for quite a while - now I think the real cause is the warping problem, but it's all costing so much money to fix that firstly the difference isn't actually that much and I don't want to take any risks of any future problems so want to go completely OEM Smile
29-03-2017, 03:18 AM #13
29-03-2017, 04:04 AM
The hub bolt is 90942-02070, if you need that.
Working backwards from the hub :
oil seal - 90311-48013
ring - 90521-77001
bearing - 90363-32035
Do you need any more ? There's a rotor, cap and nut behind the wheel bearing.
29-03-2017, 04:04 AM #14
ring - 90521-77001
29-03-2017, 05:29 AM
steviewevie The hub bolt is 90942-02070, if you need that.
ring - 90521-77001
Thanks Steve, they have given me a quote now for all the parts, and it's basically every part in the diagram except the ring thing right at the back and the hub bolts. I've asked Tony whether I need all those bits or only a few of them, hopefully it's not all of them but either way the price isn't coming out too bad as they're offering a decent discount of between 10 and 20%.
29-03-2017, 05:29 AM #15
ring - 90521-77001
29-03-2017, 10:39 AM
fl@nge and hub are the same mate....
29-03-2017, 10:39 AM #16
29-03-2017, 11:26 AM
Flange is no longer in the swear filter Ormi... :thumbup:
29-03-2017, 11:26 AM #17
30-03-2017, 12:38 AM
ormi fl@nge and hub are the same mate....
Cheers Ormi, that was definitely where all the confusion was - just need to get the bits ordered up now Smile
30-03-2017, 12:38 AM #18
Views 928
25-08-2018, 09:20 AM
Last Post by wahidhussain
