JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza What is the differential ratio of an IS200?
03-04-2017, 12:10 AM
Don't do it, I had the 4.1 ratio and hated it so much!! When the 3.9 was put back in it drove substantially better - really bad move playing with diff ratios. All the internals are swappable between the IS200 and Altezza's, just the mounts that connect the drive shafts are different - they are easy to swap though, and the Altezza drive shafts are interchangeable also.
03-04-2017, 12:10 AM #11
koka
16-04-2017, 05:37 AM
what about an is300 euro A/T diff. it has a ratio of 3.58. wolud it fit on the is200? and it is also the torsen.
the is300 A/T from america has a ratio of 3.90
the is300 M/T from america has a ratio of 3.76
koka
16-04-2017, 05:37 AM #12
16-04-2017, 05:42 AM
Different diffs mate.
16-04-2017, 05:42 AM #13
koka
16-04-2017, 07:28 AM
can you tell me who are the differents
koka
16-04-2017, 07:28 AM #14
16-04-2017, 07:40 AM
I don't think it's a straight swap between them. Do you mean putting that into an auto IS200 or a manual IS200 ?
Why would you want to put in a different diff ratio ? Putting a lower one in will slow down your acceleration but increase your top speed. It will make you do less revs at an equivalent speed, but then the IS200 isn't exactly noisy anyway ?
16-04-2017, 07:40 AM #15
16-04-2017, 07:55 AM
The IS300 ones are bigger IIRC and don't physically fit, the drive shafts are different, the ratios are wrong, I also think the bolt pattern for the prop is different - although that is a guess from something I heard Wayne (Supratruck) chatting about.
16-04-2017, 07:55 AM #16
koka
16-04-2017, 12:54 PM
It is with a manual.
I would like to spar a little petrol, because the IS200 because at the same speed lass turns.
So the whole it is not installed possible. what if you swap just the offal, so only the final gear. is that possible?
koka
16-04-2017, 12:54 PM #17
19-04-2017, 10:19 AM
I think the final drives are compatible, at least they look like they are from the parts diagrams, all the other parts are the same so I don't see how the final drives would be somehow incompatible. I've never tried it myself though !
19-04-2017, 10:19 AM #18
Views 330
13-12-2023, 02:06 PM
Views 470
09-11-2023, 03:46 AM
Last Post by Dinho
Views 700
06-11-2022, 01:49 AM
Views 1,192
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,148
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 459
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,723
04-08-2021, 04:34 AM
Last Post by cjoseph
