JapCarForum General Discussions The JCF Lounge Any Plumbers in the house??
13-04-2017, 01:32 PM
Tango Don't you have a gas torch? It's easy enough to do the job properly with a few pre-soldered fittings and copper pipe.
Nah dad used to have one cant find it, brother in law is bringing his round next week, although its so tight under/behind the sink might have to go down the self tapping route
13-04-2017, 01:32 PM #11
Saraj
13-04-2017, 02:08 PM
yep same here with the tap kit, bought mine from b and q for about 10 qiuid, took 5 minutes to install..
Saraj
13-04-2017, 02:08 PM #12
13-04-2017, 02:11 PM
Saraj yep same here with the tap kit, bought mine from b and q for about 10 qiuid, took 5 minutes to install..
is there any lack of pressure??
13-04-2017, 02:11 PM #13
Jambo
13-04-2017, 02:23 PM
PM "MarsdenDean" he will be able to tell you all you need to know. Him and his (and my) dad are plumbers :wink:
Latest Meets
Ace Cafe 16/10/10,
Jambo
13-04-2017, 02:23 PM #14
Latest Meets
Ace Cafe 16/10/10,
13-04-2017, 02:40 PM
Cheers fella, done!!:thumbup:
13-04-2017, 02:40 PM #15
14-04-2017, 12:02 AM
SHAHZ is there any lack of pressure??
No mate, perfectly fine, runs my pressure washer etc
14-04-2017, 12:02 AM #16
14-04-2017, 12:07 AM
Cool that's what I needed to know, now I just need to make sure the pipe is long enough to get to where the tap will be
14-04-2017, 12:07 AM #17
Saraj
14-04-2017, 06:19 AM
the tap kit is fine, and i have about 10 inches exposed and served no problems pressure is perfect, spray gun works fine when washing car.
much easier and cheaper then putting in a proper one, also there have a stop as the bit which it connects to the mains.
Saraj
14-04-2017, 06:19 AM #18
14-04-2017, 06:35 AM
Cool, cheers mate, wont use the kit......the tap will be placed where the pipe goes outside so none will be exposed really.....got a few plumbing shops round here that i will get the tap from, unless you can recommend somewhere online for a decent tap/double check valve/tap for under sink
14-04-2017, 06:35 AM #19
14-04-2017, 07:20 AM
Marsdendean I would just use a tap under the sink.
Idea in a double check vavle, is incase you leave the hosepipe in a pond, and the water gets turned off and cut somewhere in the house, it can draw the pond water into the house. Never really happens, but something the WRAS say you have to do.
We use PTS as they are not too bad priced, and always give money off if you barter them down!
what with a hole just for the hose to come through the wall??......aint no ponds here, will be just used to wash cars, water plants and fill kids paddling pool!
14-04-2017, 07:20 AM #20
 3 Guest(s)
 3 Guest(s)
Views 152
13-03-2019, 04:12 AM
Last Post by JonPowellDJ
Views 290
10-02-2019, 05:47 AM
Replies 47
Views 1,959
29-01-2019, 02:43 PM
Replies 23
Views 972
19-07-2018, 03:40 AM
Last Post by Carpediem
Views 391
11-07-2018, 03:16 AM
Views 864
01-06-2018, 01:11 AM
Replies 50
Views 2,684
13-01-2018, 09:26 AM
