Ford Focus ST3
Ford Focus ST3
Cheers guys. Primarily All Purpose Cleaner was used for the engine bay, plus a little engine and machine cleaner in tougher areas. As said clingfilm is always great for covering electrics. Just need to use common sense, very little water is required for rinsing. The pressure washer wasnt even turned on, just a fine spray.
amazing as always!!!!
off topic did you see the rust in the boot shut around the oval grommet!!!!!!
ormi amazing as always!!!!
There were a couple of areas of unexpected rust in places, the owner is going to contact Ford regarding this.
