JapCarForum General Discussions The JCF Lounge Compatible inks
Compatible inks
Compatible inks
12-05-2017, 03:26 AM
parthiban Cheers for the replies, that's all good stuff, I'll definitely give it a go then. In terms of refills Bandit, does that mean it'll still read the ink level correctly if you refill before it gets empty? That was the only other downside to compatibles, but this sounds like an interesting alternative.
Yes mate, a lot of the compatible cartridges now use a new generation chip so don't need to be reset, but as 2T above says you can buy a reset tool pretty cheap if needed, i just fill before empty so i don't have the hassle of doing a full prime of the printer which wastes a bit of ink? and they still give you the ink levels :thumbup:
12-05-2017, 03:26 AM #11
 3 Guest(s)
 3 Guest(s)
