will these fit??
will these fit??
What sacrafices would they do??
Also will it be harder work getting 18x 9.5 with et 50 then with et15 fitted under archs
like a bit of now and again tyre rubbing for a start
would be easier to get ET50 under but will be close to your shock around (20mm), but should clear it. the wheel will also foul outside of the standard arch by around (2mm) but easily clearable with a rolled and flared lip.
this is just a estimate of course.
think i will get 8 front then 8.5 rears
its more about the right offset than how wide the rims is.
for example probley my fav IS ever and IMO the best wheel/stance setup ever!!! is this:
Front: 18x9.5+17 | 215/35r18 | -3.1* camber
Rear: 18x10.5+25 | 235/35r18 | -6* camber
with loads of arch work.
Pure uncensored filth!!!! :thumbup1:
Be better with mat black rims.
Hate the stretched tyres, but that is some insane wheel width!
posty
would the camber not cause massive uneven tyre wear?
posty
