JapCarForum General Discussions The JCF Lounge Drivers!!
Drivers!!
Drivers!!
Pages (8): Previous 1 2 3 4 58 Next
11-08-2017, 03:55 AM
my coach I could get so close to a wall that you couldn't walk behind it, never once crashed it or put a scratch on it, can do the same with lorries.
There is a trick to it:
Park the vehicle with the rear against a wall as close as you want to go in normal driving.
Look along the side of the vehicle, in your wing mirror, is there anything that lines up with the base of the wall?
If so then as long as your mirror is in the same position you can safely reverse up to the point that the mark on your car/coach/lorry lines up with the base of the wall.
This works really well with commercial vehicles because of the amount of side markers, and stuff. Not so well with cars though as they are pretty smooth.
This "trick" is used in the LGV and PSV driving test to check your reversing ability.
11-08-2017, 03:55 AM #11
Carpediem
11-08-2017, 03:57 AM
^^ agreed,
I can see in my wing mirror the bottom inside edge of the wheel arch, i use this as my point of refernce
another trick i use is to keep your left foot on the brake just enough to set the lights off but not to add any resistance, the reflection off objects acts as a good visual marker
doing this at night times means i can park within inches using only the rear view mirror!
Carpediem
11-08-2017, 03:57 AM #12
^^ agreed,
Phil01
11-08-2017, 04:00 AM
or reverse until you hit the car behind you then pull forward 4inches, thats what I have seen today in Tesco.
Phil01
11-08-2017, 04:00 AM #13
11-08-2017, 04:03 AM
Phil01 or reverse until you hit the car behind you then pull forward 4inches, thats what I have seen today in Tesco.
Those people need parking sensors! :laugh:
I rely on my sensors quite heavily, means you can park accurately and quickly Smile
11-08-2017, 04:03 AM #14
11-08-2017, 04:07 AM
I love the rear view camera, fantastic invention. For those of us with auto park the yellow box that tells you where you will go given your current steering angle is brilliant also.
11-08-2017, 04:07 AM #15
Phil01
11-08-2017, 04:27 AM
On the Prius the yellow guide lines are great but the IPA is not so good, takes a long time to make sure your in the correct position then is not accurate.
Phil01
11-08-2017, 04:27 AM #16
11-08-2017, 04:33 AM
i stop when there is resistance but i do have a tow bar so all is good on my body work lol
11-08-2017, 04:33 AM #17
11-08-2017, 05:09 AM
I actually think the IPA is pretty good, while it can take ages to program perfectly, it generally gets it almost right on its own - so if you just let it do it and hit go 9 times out of 10 you'll end up pretty much in the space (possibly needing some minor adjustment).
Plus it's incredibly cool Smile
11-08-2017, 05:09 AM #18
Carpediem
11-08-2017, 05:12 AM
whilst being very cool, and i agree it is
will it not simply dumb-down the new-age drivers?
the amount of people i know who cant drive a car without power steering is unreal!!!
personally i love the old skool feel!
Carpediem
11-08-2017, 05:12 AM #19
11-08-2017, 05:28 AM
Carpediem whilst being very cool, and i agree it is
From my experience they're already dumb beyond belief - if making them a tiny bit dumber means my car is safe then I'm happy with that :biggrin:
11-08-2017, 05:28 AM #20
 5 Guest(s)
 5 Guest(s)
Views 253
11-02-2019, 01:19 AM
Views 304
21-08-2018, 02:51 AM
Last Post by looney
