Look What I picked Up.....
Sorry to hear it's frustrated you Keith. How about taking a pic of where you've got it almost fitted but not quite, then posting it for someone to see what they think the problem is ?
Yep, as Stevie said post a pic of how far you get with the install and where you encouter the problem. I'm sure those of us who have fitted the B&M shifter should be able to help you.
Yup defo IS200.......from 2000 onward for the IS200, mines 2001.
Inserted the ball joint/plastic cup end but just couldn't get it too go any further down, I kind of expected it to be a little tight but just drop in with a bit of pressure........but noad: Don't think a pic would help as once the end is inserted you can't see anything except the shifter sticking out? Seems to be about a 40mm gap before the blue collar at the bottom of the shifter should make contact and be bolted down......very frustrating
ad:
Keith
gutted for you M8, someone will help no doubt.
cameron the oem one is a bit of a pain to get back also.you need to make sure it is all lined up and the rite way round note the oem only goes in one way otherwise it hits the handbrake when selecting reverse.also i got a hammer and tapped it in.
Id agree with cam, a hammer could help.
