JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Supercharger upgrade parts and questions?
05-11-2017, 11:39 AM
on the lextreme page you will see the 1gfe
sky-blue 13.8 155 2.9 cone (2) 1G-FE
all you have to do is match up the 1st 3rd 4th to get the same size cone and ohm the 2nd is cc this you want 315 so you look for that.
05-11-2017, 11:39 AM #11
05-11-2017, 11:44 AM
clear as mud :biggrin:
05-11-2017, 11:44 AM #12
05-11-2017, 12:23 PM
i'm maybe not the best person to tell you what to do but i know the power enterprize injectors that are used in the is200 are the same as the 3s engine. so the 3s ge or the 3s gte mr2 or celica. so the list looks like this
3S-GE 85-89 86.0 mm 86.0 mm 9.2:1 1998 cc 103 kW@6200 rpm 175 Nm@4800 rpm Celica 2.0 GT-i 16, GT-R (ST162)
3S-GE late-89-93 86.0 mm 86.0 mm 10.0:1 1998 cc 115 kW@6600 rpm 186 Nm@4800 rpm Celica 2.0 GT-i 16, GT-R (ST182/ST183), MR2 (SW20)
3S-GE 94-98 86.0 mm 86.0 mm 10.3:1 1998 cc 132 kW@7000 rpm 192 Nm@4800 rpm Celica GT, SS-II (ST202), MR2 (SW20)
3S-GE 1998 only 86.0 mm 86.0 mm 11.0:1 1998 cc 150 kW@7000 rpm 210 Nm@6000 rpm Celica (ST202), MR2 (SW20)
3S-GE 1997–2005 86.0 mm 86.0 mm 11.5:1 1998 cc 156 kW@7500 rpm 220 Nm Altezza, Caldina GT
3S-GT (503E) 1987-199? 89.0 mm 86.0 mm 7.0:1 2140 cc kW (560 hp) Nm (471 ft·lbf) @5500 rpm 87C, 88C, Eagle HF89, Eagle Mk III
3S-GT (503E) 1987–1989 89.0 mm 86.0 mm 7.0:1 2140 cc kW (680 hp) @8500 rpm @5500Nm (471 ft·lbf) @5500 rpm 87C, 88C (Le Mans setup with CT26R turbocharger)
3S-GT (503E) 1995–1996 89.0 mm 86.0 mm 7.0:1 2140 cc kW (680 hp) @8500 rpm Supra GT JZA80 (Le Mans setup, Garrett turbocharger with 55.9mm restrictor)
3S-GT (503E) 1997 86.0 mm 86.0 mm 7.0:1 1998 cc kW (480 hp) @6800 rpm Nm (471 ft·lbf) @4500 rpm Supra GT JZA80 (JGTC setup with 45.3mm restrictor)
3S-GTE 86-89 86.0 mm 86.0 mm 8.5:1 1998 cc 136 kW (182 hp) @6000 rpm 250 Nm (184 ft·lbf) @3600 rpm Celica GT-Four (ST165)
3S-GTE 90-93 86.0 mm 86.0 mm 8.8:1 1998 cc 165 kW (221 hp) @6000 rpm 304 Nm (224 ft·lbf) @3200 rpm Celica GT-Four (ST185), MR2 (SW20)
3S-GTE 94-99 86.0 mm 86.0 mm 8.5:1 1998 cc 180 kW (241 hp) @6000 rpm 304 Nm (224 ft·lbf) @4000 rpm Celica GT-Four (ST205), MR2 (SW20)
3S-GTE 1999–2007 86.0 mm 86.0 mm 9.0:1 1998 cc 191 kW (256 hp) @6200 rpm 324 Nm (239 ft·lbf) @4400 rpm Caldina GT-T (ST215), Caldina GT-Four (ST246)
05-11-2017, 12:23 PM #13
05-11-2017, 12:25 PM
http://en.wikipedia.org/wiki/Toyota_S_engine
05-11-2017, 12:32 PM
would this help...
dimis For anyone who is interested for this Denso injector the part number is: 23250-22030
Found some information regarding the upgrade of the fuel injectors for the IS200. The altezza motor (3SGE) uses 340cc Denso injectors.
Here are the specs:
Specs:
Colour - White
Flow - 340cc
Pintle Holes - 6
Resistance - 14 Ohms (High impedance)
Denso number - 23250-74220 (Toyota number 23209-74220)
More specs:
@ 14V:
(Duration @ 14V / Pressure @ kg/cm2 / flow @ cc/min
0.76ms / 2.55cm2 / 340cc
0.76ms / 3.05cm2 / 370cc
0.78ms / 3.55cm2 / 400cc
Found a place that sells them HERE? Set of 6 works out about £96.30?
:wink:
Edited 17-12-2010, 10:16 PM by Bandit.
05-11-2017, 12:32 PM #15
would this help...
Here are the specs:
Specs:
Colour - White
Flow - 340cc
Pintle Holes - 6
More specs:
@ 14V:
:wink:
05-11-2017, 12:33 PM
Denso part number, so Chris would it work if Adrian took that number into a Lexus dealer? Where could he redeem the code and get the injectors?
05-11-2017, 12:33 PM #16
05-11-2017, 12:48 PM
ok thanks Chris , but why is the numbers at the top different from the ones at the bottom of the post that dimis posted , ie the ones in bold and these ones Denso number - 23250-74220 (Toyota number 23209-74220) ?????
05-11-2017, 12:48 PM #17
05-11-2017, 12:51 PM
From what i can tell mate, Dimis has the ones in BOLD writing, and the other ones are another option that could be used? But not 100% sure mate?
05-11-2017, 12:51 PM #18
05-11-2017, 12:52 PM
Should have thought more for dimis and his thread, sorry mate .
You know I like to wonder off topic now and again :Chair:
05-11-2017, 12:52 PM #19
05-11-2017, 01:09 PM
Its ok mate :Fish:
I'm quite interested in this myself so thought it would be better if it had its own area for us to ask questions :biggrin:
05-11-2017, 01:09 PM #20
Its ok mate :Fish:
Views 1,677
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 723
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 470
06-04-2023, 02:00 AM
Replies 24
Views 932
12-01-2023, 11:53 AM
Views 111
03-01-2023, 01:19 PM
Views 86
27-12-2022, 10:58 PM
Views 410
02-12-2022, 01:57 PM
Views 424
04-11-2022, 05:54 AM
Views 58
30-07-2022, 01:49 PM
