JapCarForum Car Manufacturers Toyota Bleeding Mr2 tips needed please
29-12-2017, 03:40 AM
purplewitch [COLOR="DarkOrchid"]The witchanics reply would be:
Flip the cute lil car onto it's side using a spatula, dunk it in a pan of water and when it stops bubbling there's probably no air in it. Remove from cauldron and strain using colander (preferably matching the colour to car for extra coolness) then drive around until dry Smile
But life is much easier with a broomstick [/COLOR]
Nah - it'd be:
Find a cute mechanic who knows what he's doing, flutter eyelashes and wave purse, leave to simmer for a couple of weeks and voila! All done...
Surely...
29-12-2017, 03:40 AM #11
Nah - it'd be:
Surely...
Sturat
29-12-2017, 07:45 AM
Just came back from a test drive/thrash.
It overheated again, blowing all the coolant out through the expansion tank!!!
I noticed that the rad. bleed tap was leaking just slightly don't know if this would create an airlock?
When i'm bleeding the rad for airlocks, I open the tap to fill the clear tubes and coolant pours out the sides, but it doesn't on the heater matrix tap? Is this the norm. or is my rad./tap buggered?
Maybe mental witch can cast a spell to sort it?
Sturat
29-12-2017, 07:45 AM #12
29-12-2017, 07:48 AM
Sturat Just came back from a test drive/thrash.
:lol:
29-12-2017, 07:48 AM #13
:lol:
29-12-2017, 07:49 AM
lol mental witch.
Your thermostat may be up the creek. It is only a couple of nuts (8 or 10mm)but a real PITA to get to, its under the exhaust manifold on the drivers side. May be worth whipping it out and testing it once the 'zorst is cool.
29-12-2017, 07:49 AM #14
lol mental witch.
Sturat
29-12-2017, 07:55 AM
Was stressed when I got back but u definitely cheered me up! Confusedhock:
Sturat
29-12-2017, 07:55 AM #15
Sturat
29-12-2017, 08:07 AM
2tongues lol mental witch.
The thermostat's brand new, do new ones sometimes not work?
Is it best to test a new thermostat before installing it?
This is the first one i've ever done!!
Sturat
29-12-2017, 08:07 AM #16
29-12-2017, 08:39 AM
Blueprint ones are known to be "sticky". However if its new i wouldn't worry that much, unless everything else draws a blank.
29-12-2017, 08:39 AM #17
29-12-2017, 08:48 AM
Mental Witch ???? seems i will be spending my weekend practising squishing MR2's with country accents into my cauldron !
29-12-2017, 08:48 AM #18
29-12-2017, 08:53 AM
You can test a thermostat by boiling it in a pan, it should open about 83-85 degrees. You'll see it open. As pointed out, if it's new it's probably OK.
When you attach the bleed tubes to the taps and open them up, they should do this:
[Image: coolant_in_hoses.jpg]
i.e. the coolant in them should both rise to the same height (which is the same height as the radiator cap in the engine bay). If they don't something is wrong! If they are too high or too low you still have air somewhere and should keep repeating the rad cap on 1 click, warm it up for ten minutes, put more in stages of the procedure.
Also if any of your taps are leaking when closed then they are knackered. If your bleed pipes just don't fit quite right so they let a little coolant out when attached then just cable tie around them for the short time that you are bleeding the system.
29-12-2017, 08:53 AM #19
Sturat
29-12-2017, 09:40 AM
The tap leaks out of its side when i undo it 3 full turns. The bleed pipes are tight and don't let any coolant out it just leaks from around the tap thread.
Can you please tell me if the top and bottom rad. taps are interchangeable? If they're identical; when swapped, both leak at the top and not at the bottom of the rad!
Do you think this might be the root of my problems? If so do you think I need a new rad?
Sturat
29-12-2017, 09:40 AM #20
 3 Guest(s)
 3 Guest(s)
Views 590
18-12-2018, 01:29 PM
Last Post by Stoney
Views 765
11-12-2018, 04:35 AM
