Refurbing Brembo Callipers
I recently read up a lot about aftermarket brakes. I think it was on Stoptec's site (or someone similar). Its quite worrying to hear an aftermarket brake manufacturer tell you that BBK's very rarely improve stopping distances? In fact, most of the time they get worse or cause unnecessary strain on the ABS system due to the difference in brake line pressure.
EDIT: here's one of the articles: http://www.stoptech.com/tech_info/wp_abs...kits.shtml
jimxms I recently read up a lot about aftermarket brakes. I think it was on Stoptec's site (or someone similar). Its quite worrying to hear an aftermarket brake manufacturer tell you that BBK's very rarely improve stopping distances? In fact, most of the time they get worse or cause unnecessary strain on the ABS system due to the difference in brake line pressure.
toxo Yeah that kind of thing doesn't surprise me. You have to remember that a true brake conversion kit will comprise 4 calipers, a suitably sized master cylinder, etc etc. If you just swap on the front brakes you screw up the brake bias, you change the amount of fluid & pressure required to excert the same amount of pressure onto the pads and all sorts. The volume of fluid required to displace the brake pistons enough for efficient braking can vary by miles. There's a guy on another forum I'm on who works for a BBK manufacturer and the amount of data they have to have about the car to correctly size a kit is nuts.
A lot of what's said in your link only applies to cars with ABS though (which is the work of the devil).
