JapCarForum Cars, Cars, Cars! General Car Maintenance Best way to clean injectors....literally (Redex need not apply)
11-04-2018, 01:06 AM
Been reading on pistonheads and it seems a few people recommend "Sea Clean" or some form of alcohol (Meth etc). I supposed deionised water or w/e may do the trick providing that they are primed with petrol again after?
EDIT: cheers for all the offers guys. All really handy <3
Shall I buy some cleaning solution and ship them off to one of you guys?
11-04-2018, 01:06 AM #11
Dark Samurai Jim I have one if you send the injectors to me with a few beer tokens Wink
your 12 thats illegal! lol
11-04-2018, 01:06 AM #12
11-04-2018, 01:07 AM
jimxms Been reading on pistonheads and it seems a few people recommend "Sea Clean" or some form of alcohol (Meth etc). I supposed deionised water or w/e may do the trick providing that they are primed with petrol again after?
Upto you mate, let me know
11-04-2018, 01:07 AM #13
11-04-2018, 01:08 AM
I was joking about the beer tokens part but it would be cheaper to get them here to stavs wouldnt it?
11-04-2018, 01:08 AM #14
11-04-2018, 01:13 AM
[Image: Old-Jamaica-Ginger-Beer-Can.gif] Sorted Big Grin
Oli, are you able to run whatever solution you want in your one?
11-04-2018, 01:13 AM #15
11-04-2018, 03:15 AM
Yes mate. Its a metal bowl that vibrates so it should take chemicals
11-04-2018, 03:15 AM #16
11-04-2018, 03:24 AM
You want them cleaning with an ASNU system. These produce before and after results and also check the spray pattern etc is correct.
I used these people for mine: http://www.injectorcleaning.co.uk/
11-04-2018, 03:24 AM #17
11-04-2018, 03:42 AM
toxo You want them cleaning with an ASNU system. These produce before and after results and also check the spray pattern etc is correct.
Just came across a similar service on ebay as it goes. Expensive, but I suppose worth it if done properly.
Only other avenue I want to explore first is if I can source some 7MGTE injectors 'cheap' instead.
11-04-2018, 03:42 AM #18
11-04-2018, 03:50 AM
I know it doesn't count for much but that place replace all 3 o-rings on each injector as part of the service too, and those things are single use. I reckon it'd cost you as much to get them from Toyota :lol:
11-04-2018, 03:50 AM #19
Mikeydinho
19-04-2018, 01:16 AM
Get them flow tested, they clean them and bring them back up to good as new, think mine was £50 to have them done. Also they can find any issues i.e if you have a bad injector. IMO its worth it dont cut cornors.
Mikey
Mikeydinho
19-04-2018, 01:16 AM #20
Mikey
Views 788
07-02-2024, 07:14 AM
Last Post by P.Nicolov
