JapCarForum General Discussions New Members Hello to all
Hello to all
Hello to all
Phil01
13-04-2018, 03:08 AM
I dont think it is tyre related really,
The poor guy has replaced all four with matching brands,
In the past I have driving with some mis-matched tyres and have never experienced severe probs like him.
Sounds like a suspension/tyre contact control eg damper/arb's or even alignment.
Phil01
13-04-2018, 03:08 AM #11
lebon
13-04-2018, 03:09 AM
Phil01 Strange problem you have there, especially if it has been to WIM, as I am sure they would have found your problem.
These cars feel planted infact one of the best at high speed.
sounds like the obvious but is the front anti-roll bar fitted securely by the clamps/rubbers and the arb links have no play in them?
Are your dampers in good nick??
Lots to check, so can you please itemise what you have replaced/checked
WIM did not find anything wrong except the toe was slightly off. Items replaced were track rod end because they were bend the oxygen sensors, 4 brand new dunlops and finally steering rack because the steering felt very vague when driving but now the steering issue is solved and a full service done 2 weeks ago.
lebon
13-04-2018, 03:09 AM #12
lebon
13-04-2018, 03:10 AM
Phil01 I dont think it is tyre related really,
Phil not 4 but 6 lol
lebon
13-04-2018, 03:10 AM #13
lebon
13-04-2018, 03:15 AM
Sorry to ask but dont all Dunlops come with reinforced side walls as mine the fronts are dunlop sport maxx and the rears are dunlop sp 01
lebon
13-04-2018, 03:15 AM #14
lebon
13-04-2018, 03:17 AM
Phil01 Was it OK prior to 4mths ago??
Yes it was great prior to 4 months ago. all this started when I found out my track rod end was bend.
lebon
13-04-2018, 03:17 AM #15
Phil01
13-04-2018, 03:19 AM
quote,, SP01,The tires feature a rayon cord reinforced casing to enhance ride quality
Quote Sport Maxx, with DuPont™ Kevlar® reinforced lower sidewalls
Phil01
13-04-2018, 03:19 AM #16
Phil01
13-04-2018, 03:20 AM
OK, why was the TRE bent??
Phil01
13-04-2018, 03:20 AM #17
lebon
13-04-2018, 03:22 AM
Phil01 OK, why was the TRE bent??
Lexus claims I had jack the car up wrongly which I did not or I have hit a pothole.
lebon
13-04-2018, 03:22 AM #18
lebon
13-04-2018, 03:24 AM
Phil01 quote,, SP01,The tires feature a rayon cord reinforced casing to enhance ride quality
So the rear tyres are not reinforced sidewalls but a rayon cord reinforced not sure what that means
lebon
13-04-2018, 03:24 AM #19
13-04-2018, 03:26 AM
Are the Sport Max not semi- run flats? and SP 01 normal? If so is there a difference between the front and back causing this issue?
i feel sure Sport Max can be run flat for a limited distance at low speed.
13-04-2018, 03:26 AM #20
 4 Guest(s)
 4 Guest(s)
