Oil cooler for PAS?
Oil cooler for PAS?
You don't actually need much in the way of PAS cooling unless you have a habit of holding your car at opposite lock a lot. Which is why they're quite common amongst drifters!
Surely it has to come from more or less the back of the engine bay to the front, so you could shorten it and relocate it to behind a foglight or something? There must be plenty of places it could go
Also remember that PAS fluid and ATF fluid are very similar, so anything suitable for cooling transmission oil should be OK. MR2 has a metal loop like your one but MUCH shorter on the gearbox, and the GT4 has a small radiator it uses as the fluid gets hotter with the transfer box in place.
boo
When i got my intercooler they give you a metal cooling pipe so you can do away with the standard pipe and relocate it to the N/S front of the car
I have a funny feeling i have another one of these in my garage, will look at the weekend mate
Boo!!! can i have it!
Sparkystav Boo!!! can i have it!
