JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Supercharger fitting help
08-10-2018, 09:28 AM
if memory serves it was a real pain to do when i first did it i know that dont help trying to find my fitting guide
08-10-2018, 09:28 AM #11
rob
08-10-2018, 11:10 AM
you just need to hammer it out - its tight.
do you have the black plastic adaptor that goes in place of the reservoir?
rob
08-10-2018, 11:10 AM #12
08-10-2018, 11:23 AM
he should have yes as bandit didnt use it
08-10-2018, 11:23 AM #13
Lexuslee
08-10-2018, 11:51 AM
Got to have a bash at it in the morning, got the adapter and a big hammer 8 )
Lexuslee
08-10-2018, 11:51 AM #14
Talisker
08-10-2018, 12:34 PM
That pin was a real pain in the bumhole to remove.
I got mine out by soaking it a couple of times with penetrating fluid then leaving it overnight, then once more in the morning before teasing it out with parallel drift (or pin punch if you'd prefer).
Penetrating fluid is your friend :thumbup:.
Talisker
08-10-2018, 12:34 PM #15
Lexuslee
09-10-2018, 05:09 AM
Right got everything fitted and it's all running fine but with one problem, when I put my foot right down the engine light comes on and the trc light flashes, then the pedal does nothing and I have to turn the car off and wait then restart and its fine until I go full throttle again. If I disconnect the bypass cable from the throttle it does not do this but there is not as much power! Any help please
Lexuslee
09-10-2018, 05:09 AM #16
Lexuslee
09-10-2018, 06:02 AM
But it was doing this before i fitted the belt and before i fitted the fcd, just seems to be when i put the bypass onto the throttle. Did i read u dont need the bypass if you havve bov
Lexuslee
09-10-2018, 06:02 AM #17
09-10-2018, 06:18 AM
Your starving the air to the car!
by putting your foot down your closing the bypass and asking the engine to suck air in through a non spinning supercharger
09-10-2018, 06:18 AM #18
Lexuslee
09-10-2018, 06:19 AM
But now it's all fitted and running and it's still doing it
Lexuslee
09-10-2018, 06:19 AM #19
09-10-2018, 06:47 AM
whats doing what?
09-10-2018, 06:47 AM #20
whats doing what?
Views 1,897
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 823
23-05-2023, 12:26 AM
Last Post by ashj25839
Views 513
06-04-2023, 02:00 AM
Replies 24
Views 1,205
12-01-2023, 11:53 AM
Views 176
03-01-2023, 01:19 PM
Views 133
27-12-2022, 10:58 PM
Views 468
02-12-2022, 01:57 PM
Views 482
04-11-2022, 05:54 AM
Views 84
30-07-2022, 01:49 PM
