JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Excessive Wind Noise
jasons
17-11-2019, 05:00 AM
rob NO!!!
never soak or spray rubber with wd40 or other petroleum based product - they will swell and perish and you will have to replace them.
Absolutely- Silicone spray only.
jasons
17-11-2019, 05:00 AM #11
rob NO!!!
jasons
17-11-2019, 05:02 AM
rob its sealant backing cord - its closed cell foam cord/backing used to fill the gap in large tile gaps before selaing or grouting. a builders merchant should have it trade name is cordex.
make a cut in the door seal, work thru a cable etc, attach the cordex, pull the cable thru and reseal the door seal wth wetsuit repair sealant
Cool, will look into that- its also been suggested on some of the US forums that this could be the cause:
Yo, sorry for the direct email but im not a member of is300,net just read all the posts for the hell of it, (im a Lexus Mechanic and own a 03 sport cross) anyway, your wind noise (spread the word as needed) is probably caused by a missing body plug under the car. It is located on the "frame rail " area by the drivers feet, the hole is oval and is designed for vehicle tie down during transport on a truck. Without the plug wind noise travels up the a pillar and sounds very similar to a "slightly open window". these plugs are on both sides of the car front and rear, and new plugs can be attained at your lex. dealer.
jasons
17-11-2019, 05:02 AM #12
17-11-2019, 08:38 AM
Awesome, thanks Rob - will check that out :thumbup:
17-11-2019, 08:38 AM #13
jasons
17-11-2019, 10:05 AM
jasons Cool, will look into that- its also been suggested on some of the US forums that this could be the cause:
Just had a look under the car and the drivers side one was missing- blanked it over so we'll see if that makes a difference...
J
jasons
17-11-2019, 10:05 AM #14
J
17-11-2019, 10:27 AM
interesting, get a quick picture of the location, just so people know where to look :thumbup1:
17-11-2019, 10:27 AM #15
Views 1,559
17-07-2021, 06:37 PM
Last Post by wullie_trd
Views 757
21-06-2021, 08:54 AM
Last Post by buzzard2011
Views 2,323
24-07-2020, 06:21 AM
Views 494
31-01-2020, 06:09 AM
Views 1,850
05-01-2020, 06:02 PM
Views 1,163
30-08-2019, 09:02 PM
Last Post by Stoney
Views 1,461
16-04-2019, 10:21 AM
Views 1,393
19-03-2018, 03:32 PM
