help!!!
help!!!
T10 SMDs will do fine. Got some in mine, very bright and the white light looks pure.
I have smd noplate lights in it already they just started flashing then went out just need to get new ones
any way i have anouther problen
i got home to hear my car clocking !!! on further inspection i found it to be the EFR relay well i think its cald that ,and a dead battary it was a new battary just the outher day !! i have lookd it up and suposidly its do do with the switch on the back of the ignition barrel .van any one shead more light on tgis and anouther thing i notisd that wen my key is out the barrel and i press the brake pedle the lights come on !! is this corect caus i dont thhink the lights are suposd to have a constnt feed !!!!
the lights should light up as far as i know.
as for the clicking, i traced mine to the security ecu that had water ingress in the drivers fuse box
ive had the clicky efi relay and had flat battery due to it switching constantly, it sorted itself somehow i never fixed it anyways if i heard it clicking i kept turning the ignition on and off til it stopped
and the brakes do light up with no ignition on
Well i changed the ignition switch at the back of the barrel and i also cheakd the foot well and alll the fuses n stuf down thear and its all dry . i was mucking about with the key in and out the barrel ,if i turn it off then remove the key as normal it clicks like mad and then i tryd turning it off leaving the key on it for a few more seconds then removing the key from the barrel and all is ok !! god knows what it is i dont have a clue but what i am doing is working so far ! and it pasd the mot on sat aswell
