JapCarForum General Discussions The JCF Lounge Home multi room speaker setup
reco2k
12-01-2019, 06:22 AM
Details here http://www.sonos.com/system/
reco2k
12-01-2019, 06:22 AM #11
12-01-2019, 06:34 AM
He sonos looks good but it's more a system to add to a house via wireless.
I'm after something wired where you can change the output from a single hub routed to each speaker.
12-01-2019, 06:34 AM #12
el_gencer
14-01-2019, 01:34 PM
have you had a look at xbmc ? i'm using openelec which is a more optimised version. with this solution you could have a central server and then have units in each room streaming the data. there is also the option to have database controlled, so if you pause in one room you can continue in another.
el_gencer
14-01-2019, 01:34 PM #13
14-01-2019, 01:46 PM
Hmm, not quite sure I understand that,
I use xbmc on my jail broken apple tv at the moment.
14-01-2019, 01:46 PM #14
15-01-2019, 01:23 AM
Proper wired systems are fairly expensive as far as I know, my brother's house has a QED system in it which does exactly what you're looking for (and I think it's quite simple as it's just a CAT5 cable that goes between each device) but I think it has a relatively heavy price tag on it.
I think something like what Rabs suggested (if it's more cost effective) might be the best option.
15-01-2019, 01:23 AM #15
el_gencer
15-01-2019, 02:41 AM
xbmc allows for a database to control the library in the background rather than have it sat locally. you then add a file to the distributed boxes that include the ip address of the database so its common to all of them.
http://lifehacker.com/5634515/how-to-syn...-the-house
el_gencer
15-01-2019, 02:41 AM #16
Views 484
24-02-2019, 08:30 AM
Views 367
03-12-2017, 04:58 AM
Views 348
22-04-2017, 12:45 PM
Views 570
24-03-2017, 01:40 AM
Views 200
15-07-2016, 02:55 PM
Last Post by Saraj
