JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Cradle Measurements
Cradle Measurements
Cradle Measurements
Pages (9): Previous 1 2 3 4 59 Next
28-01-2019, 05:43 AM
Stix has put it on hold as i read it the other day.
as there wasnt enough interest in the prices that where coming up.
i have a machine shop that can produce it very easily for alot less. but either need one to copy or descent pictures to show them so they can have a good look at them
28-01-2019, 05:43 AM #11
28-01-2019, 06:04 AM
I messaged him and he is still working on it, just trying to find a good fabricator to do it as the first one screwed it up.
I wouldn't be so quick to say they can do it easily though. lol Nothing is level, it's all odd distance and angles. Cutting bar and welding is easy, but replicating a complicated framework like that would be very hard even with one to copy. Which is why no one has managed to do it before.
28-01-2019, 06:04 AM #12
28-01-2019, 06:10 AM
I see what u mean but the guys I've got lined up build parts for the Aircraft used by the RAF so a simple frame shouldn't be to much work
28-01-2019, 06:10 AM #13
Lexuspat i have a machine shop that can produce it very easily for alot less. but either need one to copy or descent pictures to show them so they can have a good look at them
I think as Sprinter said:
sprinter2012 But unless you have a degree in design and are proficient with something like AutoCad there's no way you'd be able to give accurate enough measurements/drawing to reproduce one from.
The tolerances here are virtually nil. You will need to get every piece, every join, every angle perfect in order to have the charger pulley line up 100% straight, and spin with no vibration. Stix had the right idea with the jig. Reproducing it to the correct accuracy with a few pics and a couple of measurements I would not have thought possible.
28-01-2019, 06:10 AM #14
28-01-2019, 06:18 AM
As above stoney.
If these guys can't do it then the people saying they can make it are pretty well up the creek.
Let's not forget 2 people have already made there own with basic ability and trial and error so its worth taking in the pics and measurments to see if they can do it.
I don't see why I should pay more for a cradle then a supecharger itself when a cradle is a metal frame with no working parts.
That's just my veiw on it to be fair and some might think different but as said if these guys can't do it with the kit the RAF have then in my veiw there's no point
28-01-2019, 06:18 AM #15
As above stoney.
Fozzy
28-01-2019, 08:37 AM
If I had a cradle available I would give it a shot. I work in a machine shop, i can weld, and I come from an engineering design background. All the right boxes ticked, but no cradle to work from
I'm considering a charger build of my own at some point
Edited 10-03-2012, 06:13 PM by Fozzy.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
28-01-2019, 08:37 AM #16
28-01-2019, 08:45 AM
I'm in pretty much the same boat, I can use AutoCad and do design and fabrication etc. But without one to copy I wouldn't even bother. lol
I still think the RAF guys may struggle without one to copy though, because they must be used to working from technical drawings etc. for something as complex as aircraft components. I'd hate to think they were making parts by eye. lol
The guy that does our CNC stuff could turn/cut/tap all the bar and profile the ends to the same diameter as the bar for a neat weld etc. and is capable of working to tolerances as small as 0.001mm but without a drawing he would tell me to **** off. haha
28-01-2019, 08:45 AM #17
28-01-2019, 09:52 AM
Lexuspat Let's not forget 2 people have already made there own with basic ability and trial and error so its worth taking in the pics and measurments to see if they can do it.
Well, I read today that one of the two guys who made their own is getting unacceptable vibration, and needs to revise their design. I do not know about the other guy, but this may also be the case for him. It can be done, but can it be done perfectly?
Why you should pay more for the cradle (with no moving parts) than the charger (a precision tuned bit of kit that spins at massive rpm) is simple: You are comparing a complex custom made piece of metalwork with a used engine part from a ten plus year old (usually scrapped) Merc!
Edited 10-03-2012, 07:28 PM by Stoney.
28-01-2019, 09:52 AM #18
28-01-2019, 09:56 AM
Stoney ...You are comparing a complex custom made piece of metalwork with a used engine part from a ten plus year old (usually scrapped) Merc!
That's pretty much my conclusion, out of the £2k that people sell the charger kits for, everything can be bought as an off the shelf part (intercooler, BOV, pipework, even the charger!) or made easily (pipework/flanges).
I still think the charger kit prices need to come down a lot before I'd consider buying one as they are a wearing item so they can't carry on being £2K forever.
28-01-2019, 09:56 AM #19
28-01-2019, 10:01 AM
If we decide who is best equipped to reproduce a cradle (be it Sprinter, Hurricane, Pat, Swedish Pat or someone else), they are willing to put in the hours and I was somehow able to do without mine for a short period then a group buy could be on the cards. I know there was interest recently on Stix's thread (the main stumbling point being the cost, I think), and on this one too. Not sure I want to commit to it this minute, just thinking aloud really, but it could be an option worth discussing.
28-01-2019, 10:01 AM #20
Views 1,898
29-05-2023, 05:08 PM
Last Post by Mikedaddy
Views 470
02-12-2022, 01:57 PM
Views 989
17-09-2022, 01:50 AM
Last Post by captain
Replies 62
Views 3,381
05-06-2021, 12:09 AM
Replies 61
Views 3,748
23-01-2018, 02:52 PM
Last Post by dandydons
