My new toys
My new toys
Pages (177): Previous 118 19 20 21 22177 Next
12-10-2016, 10:42 AM
steviewevie Nice and shiny !
Next attempt is to start polishing the supercharger. Probably in the weekend. since the weather will be good this week. Shiny and warm. :thumbup:
12-10-2016, 10:42 AM #191
12-10-2016, 11:08 AM
Marsdendean What things are you using to polish things.
Im going to get the mrs to get me some stuff so i can start polishing the main block of my engine, just unsure what i need
Well mate, i got a polishing kit, which included two braces. The first brace is used to grain the metal (it looks like it is made of stiff plastic threads) and the second (made of cloth) is used to do a finishing polish. The kit also inncluded two types of waxes. The first one is used with the first brace and the second with the polishing brace. I will take some photos tomorrow if you want.
12-10-2016, 11:08 AM #192
12-10-2016, 11:26 AM
Marsdendean Yes if you could please. I think my next mod is to try and get the engine bay nice and shiny!
Ok mate, I will do it tomorrow
12-10-2016, 11:26 AM #193
12-10-2016, 11:30 AM
polishing your engine block???you sure?lot of stripping to do that!most people just paint coz its cast iron,doesn't come up too well also gets very hot so it won't stay shiney for long(if you can get it shiney).
[Image: is200-rebuild-9-small-300x222.jpg]
the block is the big black bit!
Edited 23-11-2009, 09:17 PM by ormi.
12-10-2016, 11:30 AM #194
12-10-2016, 11:40 AM
You could try cleaning up the cylinder head Dean, the bit that's on the top underneath the engine covers. That's aluminium, but just cleaning it would make it look better. Trouble is, it's quite messy under there, and doesn't look that elegant with the covers off.
12-10-2016, 11:40 AM #195
12-10-2016, 11:44 AM
Very nice Dimis, you'll soon have the polishing bug Big Grin
On the charger mate give it a good rub over with a green brillo pad (like you use to do the dishes?) if you have one first, as it'll get rid of a lot of the oxidisation on it and give it a good base for the polishing :thumbup1:
12-10-2016, 11:44 AM #196
12-10-2016, 11:47 AM
Bandit Very nice Dimis, you'll soon have the polishing bug Big Grin
Thanks for the tip mate. :thumbup1:
12-10-2016, 11:47 AM #197
12-10-2016, 11:50 AM
i made a shiney engine cover for mine(bandits template) as has been said its not nice with out the covers.when you fit the induction kit you loose the big air box which is a cover as well.so fitting a induction kit makes it sound better but make the engine bay look messy.
12-10-2016, 11:50 AM #198
12-10-2016, 12:00 PM
Just to clarify, I think you mean one of those green nylon scouring pads, right ? Not a metal brillo pad ?
ormi i made a shiney engine cover for mine(bandits template) as has been said its not nice with out the covers.when you fit the induction kit you loose the big air box which is a cover as well.so fitting a induction kit makes it sound better but make the engine bay look messy.
Yep, very nice solution :thumbup1:
Actually that would be a pretty easy thing to get made Dean, you just need to make a cardboard template and get it to the exact right size/bolt-holes etc, and then take it to a metal fabricator to cut out of some nice shiny steel Big Grin
12-10-2016, 12:00 PM #199
12-10-2016, 12:01 PM
steviewevie Just to clarify, I think you mean one of those green nylon scouring pads, right ? Not a metal brillo pad ?
You could also try carbon fiber instead of steel
12-10-2016, 12:01 PM #200
 3 Guest(s)
 3 Guest(s)
