JapCarForum General Discussions New Members new S2000 owner in east anglia
Pages (34): Previous 123 24 25 26 2734 Next
RCarter
30-09-2023, 08:33 AM
Quick 5 minute mod when i finished work. Changed the horrible yellow interior bulbs for some multi LED strips, not much change in terms of lighting inside, due to the diffuser cover, but at least the yellow tinge has gone.
Before:
[Image: 58bbea14820008548a5d780daaf5362d.jpg]
After:
[Image: bdc70002272d78e18bdc80d815cb2b35.jpg]
[Image: 53a55c067eecf8073c3a6c548dd4f168.jpg]
Did try out some red LED's between those two, hated it, looked like a brothel:
[Image: 2a69afb6da6f39cd697b8737bcfee03a.jpg]
[Image: 3adf01301a5b8868ee573309ed235801.jpg]
RCarter
30-09-2023, 08:33 AM #241
Before:
After:
RCarter
30-09-2023, 08:41 AM
[Image: 7a30668874754539f33f0bb4bd8bb62c.jpg]
...gross. Haha
RCarter
30-09-2023, 08:41 AM #242
...gross. Haha
is200turbo
30-09-2023, 09:27 AM
I would say second if you plan on putting a cooler in if not then the 3rd for me
is200turbo
30-09-2023, 09:27 AM #243
30-09-2023, 11:45 AM
I think you should fit both leds with a changeover switch, just in case you want the "red light special"
30-09-2023, 11:45 AM #244
RCarter
30-09-2023, 11:48 AM
Sparkystav I think you should fit both leds with a changeover switch, just in case you want the "red light special"
....whew, wouldnt know where to start hahaha
RCarter
30-09-2023, 11:48 AM #245
RCarter
30-09-2023, 12:04 PM
The cover has a weird pattern on it for the 'reading lights', and very little space inside there. If i can take out the mounts that are in there then i might be able to squeeze them in the other way (front to back, rather than left to right)
RCarter
30-09-2023, 12:04 PM #246
RCarter
02-10-2023, 07:56 AM
[Image: 529f598bb7cfe24af5925a9a3eafbdb4.jpg]
...mint
RCarter
02-10-2023, 07:56 AM #247
...mint
RCarter
02-10-2023, 09:28 AM
So after a little reading, im a little calmer about this light being on, its not flashing, so its not a 'catastrophic failure'. But ive ordered a diagnostic kit, so at least i can pull the code.
Only issue is that this wont arrive for a week...so now its just a case of waiting
RCarter
02-10-2023, 09:28 AM #248
03-10-2023, 02:05 AM
Hope it's nothing serious mate
03-10-2023, 02:05 AM #249
RCarter
06-10-2023, 08:17 AM
So...turns out i had a misfire on cylinder 2. And the spark plugs are very old by the looks of things. Considering they were only meant to have been changed in june, i would expect the element bit to be as short as it is.
Anyway, if they were changed in june (im now wondering if my oil filter and brake fluid was changed, it doesnt seem like a great garage) would it be worth getting the NGK plugs, at almost double the price of the standard bosch ones, or would it make zero difference?
RCarter
06-10-2023, 08:17 AM #250
 11 Guest(s)
 11 Guest(s)
Views 298
16-02-2024, 09:49 AM
Last Post by Jimbob-T-Lex
Replies 22
Views 664
04-01-2024, 12:06 AM
Last Post by Jdesousa
Views 332
18-08-2023, 11:33 AM
Views 348
23-06-2023, 02:26 AM
Views 228
20-03-2023, 09:20 AM
Last Post by kevinsgs300
Views 283
11-11-2022, 06:37 AM
Views 134
11-12-2021, 11:12 AM
Views 351
01-11-2021, 11:51 AM
Views 336
18-10-2021, 01:46 AM
Views 274
14-09-2021, 08:21 AM
