JapCarForum Cars, Cars, Cars! Project Cars another is200 project
Pages (37): Previous 125 26 27 28 2937 Next
john wan
11-05-2021, 06:14 AM
Thats ok Im a carpenter I dont pretend to be a pro welder mate once its all ground down itll be fine still atleast im giving it a go most people wouldnt
Tosh what do hou mean thick? An cause im running a turbo set up allready im trying to use the down pipe again without modding it so gonna do the elbows out like ive done in the picky bit from both sides an then flange ontop
john wan
11-05-2021, 06:14 AM #261
11-05-2021, 11:47 AM
That's Ok mate. It's just I could have done a professional job for you if you only spotted it together
11-05-2021, 11:47 AM #262
john wan
11-05-2021, 12:32 PM
Thats it tho bud I want to have a go as ive got all the bits sat there for ages but didnt feal up to it now i wanna try an see what happens an once ive ground it all up it will look loads better you dont know untill you have tried it getting someone else to do it is easy :closedeyes:
john wan
11-05-2021, 12:32 PM #263
Tosh21
12-05-2021, 01:17 AM
I mean the tube is very thick for an exhaust. Not that it matters, itl last longer and move less at that thickness. Check your penetration before.grinding it off. Have a feel inside the tube see.your weld has gone.through. It looks far too cold to have penetrated though, should've ground a channel into the joins. If you have no penetration and you grind off the weld itl make it much weaker and prone to cracking.
Definitely would've ground a channel, purged it and tig welded it but like you said atleast you tried
Tosh21
12-05-2021, 01:17 AM #264
john wan
12-05-2021, 02:03 AM
Yeah ive ground the meeting ends into a v so the weld will sink into it looking inside the tube has a burn on it where the welds are an yeah I thought thicker can only be good if it cracks oh well more welding needed
When I was doing it the pipe was glowing bright redBig Grin
Edited 23-06-2014, 11:38 AM by john wan.
john wan
12-05-2021, 02:03 AM #265
john wan
16-05-2021, 11:55 AM
So got buisy today decided to make it with pre made tees
[Image: 20140627_185009_zpsgpiykal4.jpg]
Edited 27-06-2014, 09:31 PM by john wan.
john wan
16-05-2021, 11:55 AM #266
john wan
16-05-2021, 11:59 AM
[Image: 20140627_192913_zpsjtkkegys.jpg]
An before I get that looks **** there **** welds its twisted its not finished I have to grind down some welds an its not sat propperly on the studs so its flopped forward an tosh youl like these tees there 5mm thick
Edited 27-06-2014, 09:36 PM by john wan.
john wan
16-05-2021, 11:59 AM #267
Tosh21
16-05-2021, 12:08 PM
haha 5mm? you crazy man. That must weigh a ton :laugh: looks much better ground off though, you gona wrap it too? no one can complain about it then!
Tosh21
16-05-2021, 12:08 PM #268
john wan
16-05-2021, 12:13 PM
Supprisingly not as bad as youd think got some black engine paint was gonna do it with that dunno if I can be arsed wraping it its a propper pain
john wan
16-05-2021, 12:13 PM #269
16-05-2021, 12:20 PM
Ok I'm sorry for hurting your feelings slagging of your welding . lol
But it's looking much better now
16-05-2021, 12:20 PM #270
Views 5,065
09-04-2024, 01:09 AM
Views 1,278
06-04-2024, 05:57 PM
Views 1,495
04-04-2024, 03:25 PM
Last Post by DannyStock
Views 102,696
25-03-2024, 02:10 AM
Views 9,073
23-03-2024, 03:45 PM
Views 20,195
18-02-2024, 11:42 PM
Views 67,567
08-02-2024, 01:53 AM
Views 404
18-12-2023, 02:55 AM
Views 1,472
08-10-2023, 03:59 AM
Views 3,125
04-10-2023, 03:52 PM
