Lexus is200 se
Lexus is200 se
Can't wait to get it fitted, does a warn clutch make the revs drop when pulling up to a junction
I wouldn't of thought so mate that's more of a mapping issue or vacuum leak
It only does it pullin up to a junction and drops to about 500rpm then goes back up to 750.
The car is not turbo'd yet mate so only on standard Ecu strange as it doesn't do it if you are stationary and rev it
Tps maybe or a vacuum leak possibly
It's just annoying more than anything.
The gauge pod turned up this mornin and I've just ordered the gauges. Innovate mtx-u dual oil temp and pressure and a dual boost and shift light, I just need to order the innovate afr gauge then I should be protected.
I just need to find a sandwich plate or is there another way of fitting the temp and pressure sensors
Will this be ok for the is200
Yep they should work mate.
Cool will I need to take the original oil cooler off
These are the gauges I've ordered should be here tues
All will be black faces and black bezels
