JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications 140mm Pulley with Blackbox/FCD
Pages (3): Previous 1 2 3
17-06-2019, 04:57 PM
All the euro guys swear by the dark green injectors that are used on the 1ZZ, which are part number 23250-22040 DENSO.
The boost generated is directly linked to the pulley size:
130mm = 0.3bar
140mm = 0.4bar
150mm = 0.5bar
The optimum setup seems to be a 140 or 145mm pulley with the 1ZZ injectors which is just straight swap parts, no mapping involved and will give you 220-230hp.
I'm yet to get price and availability on the injectors from Toyota but they are about £20 each on eBay USA.
17-06-2019, 04:57 PM #21
130mm = 0.3bar
140mm = 0.4bar
150mm = 0.5bar
buzzard2011
18-06-2019, 02:29 AM
nice shout sprinter,
i may get some of them,as i say im running around 0.4-0.43 boost and have never realy noticed any problems apart from maybee a bit lean on top end but not so much that its that noticable,i think it may be down to the fcd more than anything.
i may have to invest in one of patricks boxes and see if it makes a diffrence.Big GriniscoStu:
buzzard2011
18-06-2019, 02:29 AM #22
18-06-2019, 03:32 AM
buzzard2011 nice shout sprinter,
The euro guys say that even a 145mm pulley is perfectly safe on stock injectors as long as you stay away from the redline. So it should be fine for 'spirited driving'.
But in the interests of safety, they say the injectors should come very soon after the pulley upgrade.
And I'd definitely get one of Patrik's black boxes as everyone on here who has replaced a FCD with one has had nothing but praise for the difference :thumbup1:
They also say that even with a remap, the 160mm pulley is just too much boost for the 1G-FE engine which a couple of our guys run.
18-06-2019, 03:32 AM #23
18-06-2019, 04:53 AM
Just had a more specific response on the setup I'm looking at from one of the euro guys, with a 140mm pulley, decat manifold and 1ZZ injectors you can expect 230-240hp at the flywheel.
18-06-2019, 04:53 AM #24
buzzard2011
18-06-2019, 08:27 AM
yeah that sounds good,
de cat for me next i think,and maybee some of them injectors.:lol:
buzzard2011
18-06-2019, 08:27 AM #25
18-06-2019, 09:07 AM
I have some injectors off the 1ggte. Must test them and see which they are.
18-06-2019, 09:07 AM #26
 4 Guest(s)
 4 Guest(s)
Views 710
23-05-2023, 12:26 AM
Last Post by ashj25839
Replies 168
Views 6,918
03-07-2022, 02:56 AM
Views 282
01-07-2022, 12:38 PM
Last Post by lexusdaydreaming
Views 476
14-09-2021, 07:43 AM
Last Post by P.Lindblom
Views 353
26-07-2021, 11:20 AM
Last Post by reganlives
Views 333
13-03-2021, 05:38 PM
Last Post by deccie22
Views 529
17-09-2020, 03:53 PM
Last Post by gsitlv
Views 683
05-09-2020, 12:06 AM
Views 298
02-06-2020, 01:57 AM
Replies 59
Views 3,668
21-06-2019, 10:05 AM
Last Post by buzzard2011
