JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Full beam is awesome - regular beam, not so awesome... HID conversion?
01-07-2019, 08:17 AM
Hids are well worth it I only have them in my dip beam and haven't used my full beam since I have the 4300k ones and they give a great light out put
01-07-2019, 08:17 AM #21
02-07-2019, 12:43 AM
Matt_C No idea - I'm really hoping someone will link to a kit they've bought, or that is right for what I want, so I know what I'm looking for!
I bought THESE, probably no need to spend that much any more but I've been really happy with them.
The reflector bulbs do give you a neater cut off as my earlier pic, but annoyingly the holders in the IS200 aren't quite straight so it isn't perfect.
02-07-2019, 12:43 AM #22
Matt_C
02-07-2019, 12:45 AM
Thanks for the link - little out of my budget though!
Matt_C
02-07-2019, 12:45 AM #23
reganlives
02-07-2019, 02:47 AM
Matt_C This one?
http://www.ebay.co.uk/itm/BI-XENON-HID-C...3597wt_922
Yeh thats the one!
reganlives
02-07-2019, 02:47 AM #24
Matt_C This one?
Yeh thats the one!
reganlives
02-07-2019, 02:48 AM
Just noticed that the link you posted is for the wrong fitment though so make sure you get the right fitment!
reganlives
02-07-2019, 02:48 AM #25
reganlives
02-07-2019, 02:49 AM
Leave it with me mate and I'll find what you need but what year is your car as the bulb fitment changed at one point...
reganlives
02-07-2019, 02:49 AM #26
jomo
02-07-2019, 03:00 AM
Hey guy's i'v got my mot end of this month, did we find out if the is200 will pass an mot with hids in or not?
jomo
02-07-2019, 03:00 AM #27
jomo
02-07-2019, 03:02 AM
reganlives Leave it with me mate and I'll find what you need but what year is your car as the bulb fitment changed at one point...
http://www.ebay.co.uk/itm/35W-HID-XENON-...84#vi-tTbl
Cheapest i could find on ebay.
£19 posted thats fecking cheap mate....
jomo
02-07-2019, 03:02 AM #28
reganlives
02-07-2019, 03:05 AM
The IS200 will pass with HID's in mate. I know that mot rules are changing but I spoke to my mechanic when I had my mot done in march and asked him about the HID rumour and he said not to worry and its something that they won't be doing people on. I had my HID's in the car at the time and he wanted a set himself!
This is what my mechanic said though so I can't be held responsible if other mechanics looks at it differently but from what I am aware there's nothing happening with MOT's and HID's.
Matt_C:
fogs are same as dipped beam HB4 then from 2003 the fogs changed to H3
full list courtesy of Bandit Wink (hope you dont mind mate)
Bulbs for IS200 99-
Dip Beam - 9006/HB4
Main Beam - 9005/HB3
Sidelight - 501w /T10/W5W
Side Turn - 501w /T10/W5W
Front Fog 99-2003 - 9006/HB4
Front Fog 2003- H3
Front Turn Indicator - T20 /7440/582
Rear High Mounted Stop Light - 955
Licence Plate - 501w /T10/W5W X 2
Rear Fog - T20 /7440/582
Reverse light - T20 /7440/582
Rear indicator - amber 582y/7440/T20
Stop/Tail - R580 /w21\5w
Interior Middle Dome - 269 /festoon 31mm
Interior Front - Ba9
Glove Box - R286 / 5mm
Ignition barrel ring - R286 / 5mm
Door Marker lights - 501w /T10/w5w
Boot Light - 501w /T10/w5w
reganlives
02-07-2019, 03:05 AM #29
Matt_C:
Bulbs for IS200 99-
Dip Beam - 9006/HB4
Front Fog 2003- H3
Matt_C
02-07-2019, 10:13 AM
jomo http://www.ebay.co.uk/itm/35W-HID-XENON-...84#vi-tTbl
Thanks for that - and using the list Regan posted, I want the 9006 HB4 bulbs, in 6000k, correct?
Not knowing anything about installing HID's though, is the above kit gonna be as simple plug'n'play as say, this kit;
http://www.ebay.co.uk/itm/Lexus-IS200-99...608wt_1021
Which is only £8 more, but is from a UK source...
However, the only thing that concerns me is this (from the one above)
"H4 Bi-Xenon, MOVING-XENON BULBS
In a typical low beam conversion, a twin filament halogen lamp is replaced by a single arc discharge burner. After this installation you will lose the use of your high beam.
XENONSHOP.CO.UK HID presents a solution to this problem by combining low and high beam functionality in a single lamp. This is done by simply moving the light source to reflect at the high beam's normal position. The HID light operation is not interrupted during the switch from high to low."
Now I presume I don't have to worry about this, since I'll only be replacing the dipped beam bulbs, leaving the high beam bulbs as they are, so flicking between high and dipped beam will be just as it is at present, and the "moving" bulbs won't actually move?
Matt_C
02-07-2019, 10:13 AM #30
Views 302
10-03-2020, 08:16 AM
Last Post by Colin G
Views 471
18-06-2019, 03:14 AM
Last Post by Kevpr
Views 599
11-06-2017, 09:01 AM
Views 867
13-08-2016, 01:00 AM
Last Post by cegifer
Replies 18
Views 997
11-08-2016, 05:32 AM
Views 1,020
14-05-2016, 09:18 AM
Views 358
12-05-2016, 02:12 PM
