JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Shopping list
Shopping list
Shopping list
22-12-2019, 04:23 PM
Cheers! Will do. Drop me a PM with your number!
22-12-2019, 04:23 PM #21
23-12-2019, 05:56 AM
I've been having a think about cooling, I want to use a toyota aygo automatic radiator for the air to water intercooler, as this means I should be able to use the bottom ports for cooling the engine oil or supercharger oil (normally for auto transmission fluid).
Anyone got any thoughts on this? Should be a fairly elegant solution to provide both on one mount.
Edited 02-02-2013, 04:07 PM by el_bandido.
23-12-2019, 05:56 AM #22
Rolex
23-12-2019, 12:23 PM
I would strongly recommend speaking to Dave and Wayne how fitted his rotrex charger.
I remember speaking to Dave about it wayne had a major job on his hands to make it fit properly.
Rolex
23-12-2019, 12:23 PM #23
26-12-2019, 11:32 AM
Will have a GTE head and block (with no pistons/rods) available at some point, is this of interest to anyone?
Edit: and 5 speed gearbox
Edited 05-02-2013, 09:09 PM by el_bandido.
26-12-2019, 11:32 AM #24
26-12-2019, 11:57 AM
I'll take it off you if you give it away? found a whole engine then?
26-12-2019, 11:57 AM #25
26-12-2019, 12:02 PM
Waiting for the guy to get back to me with a shipping quote, but yes, found an early one with the air to water intercooler I want and it's low mileage, complete with a gearbox. Only problem is, it's in New Zealand.
Might try to recoup some cost on things like cambs and manifolds, but everything else is yours in exchange for mechanical/electrical assistance :p.
Edited 05-02-2013, 09:38 PM by el_bandido.
26-12-2019, 12:02 PM #26
26-12-2019, 12:17 PM
Bit of a trek for it lol.
Problem is no one wants spares for the GTE, ive weighed in about 4 inlet manifolds and 2 sets of cams.
26-12-2019, 12:17 PM #27
26-12-2019, 12:18 PM
Inlet manifold I'm probably going to need. Zorst might be useful for someone. Anything I don't need you can have to be honest, saves me finding a place to put it. Might use the sump as well, though I suppose I'd have to block off the lines for the turbos (if they come from the sump).
26-12-2019, 12:18 PM #28
26-12-2019, 12:37 PM
nope they come from the block,
you cant use the sump as itll be a middle sump probably, not the front sump you need for the IS (the standard one).
26-12-2019, 12:37 PM #29
26-12-2019, 12:45 PM
balls. Ok, will have to hope mine isn't damaged.
Edit: Do you want the bits I take out of the 1gfe as well?
Edited 05-02-2013, 11:15 PM by el_bandido.
26-12-2019, 12:45 PM #30
Views 406
16-09-2020, 08:26 AM
