rob Good to hear, that was the 2 bits going to the oil cooler?
Rob, yes for mine it was the 2 bits going to the oil cooler. If I remember correctly it was one of mine that split but whilst changing one I noticed the other one was on its way out as well so I changed that as well. Just be very careful with the oil cooler pipes are they are thing and can bend very easily. I found it quite difficult to change them probably as I was doing it all with the bumper still on but only my grill removed but as long as you use some WD40 to lubricate it and also heat the pipe up first by putting it in some boiling water you should be ok.
